What's going wrong?
Discussion in 'Medium Format & Large Format' started by stubbsk, Nov 30, 2007.
  1. stubbsk
    stubbsk TPF Noob!
    Nov 25, 2007
    112
    Manchester, England.
    I know this picture is kind of lame but I just wanted to know what is technically wrong with the negative if anyone can help? It's 5x4 and beyond repair but this is an extreme case of what I usually get.
    [​IMG]
    And here.
    [​IMG]
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    A couple important questions:
    1) What film is this?
    2) Is this a scan from a print or a neg?
    3) If it's a scan, are you doing it yourself? If so, what equipment and software are you using?
  3. stubbsk
    stubbsk TPF Noob!
    Nov 25, 2007
    112
    fujifilm npl
    neg
    myself, canon 1240 (i think) with film scanner adapter.
  4. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    My first thought is that your software is failing to compensate for the colored film base. Have you had similar problems with other color neg films, or in other formats of film?
  5. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    It looks like all you need to do is to set the end points correctly in each channel - that will compensate for the colour of the masks (Max, it isn't the the base that is coloured). Does your software have a histogram for each channel? Why do you think that it is a problem with the negative?
    If you have problems you might like to try ColorNeg. I don't use it, but I know a couple of people who do.
    Best,
    Helen
  6. stubbsk
    stubbsk TPF Noob!
    Nov 25, 2007
    112
    I have CS3 and have fixed the color and the exposure. A friend scanned her neg just before me with no color shift and then mine came up like that. Is it normal then for a neg to need this much pp?
  7. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Normally the scanning software will adjust the colors correctly for you. Did you follow the same scanning workflow as your friend?
  8. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I think everyone is making the rong assumption here. Have you made any prints from this neg? are they still this dark? what are you using for lighting? it seems to me your images are just under exposed and mbye you need to change the position of your lighting what are you using?.
