What's the difference between different circular polarizers?
Discussion in 'Photography Beginners' Forum' started by RockDawg, May 15, 2008.
  1. RockDawg
    RockDawg TPF Noob!
    Mar 29, 2007
    156
    NE Ohio
    I am looking to buy a circular polarizer for my Nikon 18-70 lens and I'm a bit confused on the different types. Take the 67mm Hoya for example. at Adorama they list:
    Hoya 67mm Circular Polarizer Glass Filter
    Hoya 67mm Circular Polarizer Multi Coated Glass Filter
    Hoya 67mm Extra Thin Circular Polarizer Super Multi Coated Glass Filter
    Hoya 67mm DMC PRO1 Digital Circular Polarizer Glass Filter
    What is the real world difference betrween them (I've read Hoya's site, but the technical mumbo jumbo doesn't mean much to me)? Also, how do you know if you need a "thin" version. They say it helps avoid vignetting on wide angle lenses, but how wide a lens befire you need one?
  2. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    The multi-coated lenses help to reduce flare on metallic objects. I think the example I saw was on a 10 pence piece (of course, that was a bit of marketing skills :)). The extra thin one probably does help a bit with very wide-angle lenses, but it's difficult to tell just how wide you can go before vignetting occurs. I guess the only real way to find out is by trying one yourself.
    As for the PRO-1 filter, it basically means that the glass is of a higher quality. Whenever you put a piece of glass on top of another 9-18 pieces of glass (i.e. your lens), it will degrade the quality, no question. The PRO-1 series, however, don't degrade the image quality as much, at the cost of your hard-earned cash ;)
    I, personally, don't own a polariser, so I can't really tell you the real world difference, but the only way to make absolutely sure is to try each one out for yourself, then make a decision.
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    The first part is easy...some are multi-coated or have some special coating to help reduce flare etc. They are more expensive than filters without fancy coatings. A thin filter will usually be more expensive. Some wide angle lenses can vignette with thick filters, so that's where you would need a thin filter.
    There is of course the quality of glass to consider and the most expensive filters will usually have top quality glass.
    As with anything else, the brand name will make a difference.
  4. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    Generally more than two filters stacked on a 28mm (35mm film format) lens will begin to cause vignetting. A thin filter would only help if it meant the threads were shallower. But then all of the filters would have to be the same and you might be able to get away with three, max.
  5. RockDawg
    RockDawg TPF Noob!
    Mar 29, 2007
    156
    NE Ohio
    So after the coatings it's pretty much better glass that is all that seperates them? Are there any real world or measurable differences between the mid and high end if they both have a coating?
    Also, am I correct in assuming that if you have larger diameter filters and use a step up ring that would help minimize vigentting that could result from stacking?
  6. RockDawg
    RockDawg TPF Noob!
    Mar 29, 2007
    156
    NE Ohio
    Thanks. I figured there were no hard and fast rules governing this, but I appreciate the general guideline of two filters on a 28mm (~18mm on my D80). That's exactly the type of info I was looking for.
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Quick call the doctor. This man is a victim if marketing!
    The first three is easy. Hoya offer filters with varying levels of anti-reflective coatings on them. The filter in the list I would choose is the 3rd one down the SHMC extra thin polariser.
    That last one is marketing BS. Or do you really think Hoya has made a filter that some how works magically better for our digital cameras? What makes our digital cameras different from film cameras on that side of the lens? Nothing. The light doesn't care if it'll end up on the film or on a digital sensor.
    "Digital Multi Coating" Is a method invented by hoya to separate fools from their money. I have found no visible difference in the performance of my lenses with and without SHMC filters even when nitpicking at 100%. I've posted results of the tests on this forum previously too. But by all means if you believe that you have a digital sensor therefore you need thinner glass on the filter then the Pro1D filters are the ones for you.
  8. TamiyaGuy
    Jun 25, 2007
    1,078
    Chelmsford, UK
    I guess it is a lot of marketing crap, but the Pro-1 series does definitely have better quality glass in their filters. Either that, or they're adding £40-odd to the price for nothing :meh:. Of course, whether or not the difference would actually be distinguishable from the "bad" polarisers, I have no idea. However, I do agree that a specially-designed digital filter is absolute rubbish. It's light, what more can I say? :D
  9. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    I think it's marketing hype too... but, here's a reason I've heard people throw around before and I'm interested in your opinions on it.
    I've 'heard' that the digital filters have an extra anti-reflectiveness (can't think right now) built in to stop the light actually reflecting off the sensor and back.
    But isn't film shiny too?
  10. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Film has a mat appearence to it on side that gets exposed, but I have heard no such thing about digital filters being any different than film filters.
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Oh it is, the first one is definitely a bad polariser. I know I have one here. But I have UV filters in the other categories, one is a SHMC (my preference) and one Pro1 which was on a lens I bought second hand.
    They both look the same, weight about the same, perform the same, and in both cases are 100% unidentifiable when used on sharp lenses when they are not causing ghosting, and both still cause the same kind of ghosting (single additional purple image of light source with no loss of contrast in the rest of the image).
    I'm not sure where you see this better quality glass, but I hope to god you're not relying on what's written on the package. Afterall the Hoya SHMC was top quality glass before digital cameras came out, why should it suddenly not be? Can you provide me with any evidence to the contrary?
  12. TamiyaGuy
    Jun 25, 2007
    1,078
    Chelmsford, UK
    Very good point, Garbz, Hoya is one of the best filter makers out there. But I can't help but think that there must be some difference between the SHMC ("bad"), and PRO-1 ("good") polarisers. Otherwise you're paying, what, 2 times more money for nothing??? That's bordering on fraud.
    I do agree with both you and Battou, I would get the SHMC as well, and the real-life difference would probably be indistinguishable, but there has to be some difference, no matter how small... :D
difference between thin film and coating polarizers
difference hoya circular filter
differences in circular polarizers
what is difference uv and antistatic lens filter
