Whats the difference
Discussion in 'Photography Beginners' Forum' started by Tighearnach, Jan 7, 2008.
  1. Tighearnach
    Tighearnach TPF Noob!
    Oct 26, 2007
    224
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    The 12-24 is a full-frame 35mm lens whereas the 10-20 is designed for the 1.5/1.6x cropped bodies and won't work at all on a full frame DSLR (1Ds/5D) or 35mm film bodies.
    10mm on a crop body is only equivalent to about 15/16mm in full 35mm terms, so a 12mm on a full-frame body will still be wider and have larger angle of view than 10mm on a crop body.
    Does that make sense? lol
  3. Tighearnach
    Oct 26, 2007
    224
    Thanks Mav had a feeling that was the case. Do you know if Canon have a similar lens made specifically for the cropped sensor?
  4. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    I believe the sigma that you were looking at is the widest wide-angle you can get (other than a fish, but most people don't want that severe of distortion).
  5. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    Canon has the EF-S 10-22mm which is supposed to be an excellent lens from what I've heard, and around $600 USD. It's a better lens than the Nikkor 12-24 f/4 which is over $1000! :grumpy:
  6. nicfargo
    nicfargo TPF Noob!
    Jan 4, 2008
    369
    Nebraska
    All of Canon's EF-S lenses are for cropped bodies only. What do you shoot with?
  7. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    first post = XTi ;)
  8. nicfargo
    nicfargo TPF Noob!
    Jan 4, 2008
    369
    Nebraska
    thanks Mav, I really need to learn to read better.
  9. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    I think that its worthwhile to note that EF-S are designed for 1.6 crop bodies except the 10D the 1d series have a 1.3x crop, I believe however, that the 1D/s MK III can use EF-S lenses but it utilizes a smaller portion of the sensor, I do not think that the MK I/II can use EF-S.
    So, Current EF-S Compatibility line up- XT, XTI, 20D, 30D, 40D
  10. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    And you know the 12-24 is a lesser lense why now? Is it because you have one or, shot with one? Im just curious as to where you came to your conclusion.
  11. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    The 10D is a 1.6x also.
  12. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    Because a certain well known Nikon shooter whose name I shall not mention who also reviewed the Canon mentioned that a) it's a lot wider, b) has far less distortion than any other crop factor wide angle zoom on the market including the Nikon, c) it's a lot cheaper and actually affordable, and d) the lens made him want to seriously switch to Canon
