Whats the difference?
Discussion in 'The Black & White Gallery' started by videoboyje, Jun 4, 2008.
  1. videoboyje
    videoboyje TPF Noob!
    May 24, 2008
    Harrisburg
    Im fairly new to photography, and i have wondered something for a while. Is it better to shoot in B/W or use gray scale on a colored picture later? Is there a quality difference between the two? Do you guys usually shoot in B/W or use gray scale later? Thanks guys.
  2. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    I think Grey scale doesnt have any true blacks-so the picture wouldnt be true black and white...I may be wrong though
  3. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    In addition, an advantage of shooting in color is that one can always change it to black and white later, particularly changing the levels and being able to create a higher contrast, more interesting image.
  4. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,997
    497
    L.A.
    Whatever works best for you is better and it's better because it works best
    for you.
  5. Miaow
    Miaow TPF Noob!
    May 25, 2007
    885
    South of Melbourne, Australia
    I like to shoot in colour and then convert a pic - Sometimes what I thought would work well as a B&W didnt and was actually better in colour - At least shooting in colour if the pic doesn't work as a B&W you can still go back to the colour version whereas shooting in B&W you cant go back...
    Grayscale true doesn't really give a great black and white conversion I've found - I've been using the dual tone conversion in PhotoImpact (dont have photoshop) recently rather than grayscale (monotone) as it gives better colours and I can also use the red filter if needed.
  6. BrandonS
    BrandonS TPF Noob!
    Feb 4, 2008
    187
    Oklahoma City, OK
    It should be noted that if you shoot raw, at least on my D80, it doesn't matter if you have it on B&W or not. The RAW file will still be color. I would imagine it'd be the same with all cameras.
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    If you shoot digital, converting into gray scale by simply setting saturation to zero will not give very good b&w results. Normally you would have to work a bit more on it.
    So if you want no effort, shoot b&w directly in camera. If you want optimised results and flexibility, shoot colour and convert in postprocessing (more tedious, search for tutorials ... or get a plugin ;) )
  8. TrickyRic
    TrickyRic TPF Noob!
    Jun 1, 2008
    264
    Toronto, ON, Canada.
    I generally shoot in colour and later decide that some shots may look better converted, in which case I use UFRaw to process the raw file again.
    I visit Niagara Falls quite regularly though, since my family live in England and you just have to see Niagara when you come out here. I've decided that next time we visit, I'll shoot entirely in black and white using the camera settings. Shooting the same water fall over and over gets somewhat repetitive and I'll be interested to see what I can pull off.
    I don't really think there's any right or wrong method for doing things. As a programmer I've been brought up with the concept that if something works, you did it right. Everybody has there own methods and styles regardless of the result. It's the same here.
  9. Samriel
    Samriel TPF Noob!
    Nov 30, 2007
    325
    Fukuoka, Japan
    Any tutorials and plug-ins for Photoshop or Lightroom you would recommend?
