What's the purpose of a Neutral Density filter that underexposing can't do?
Discussion in 'Photography Beginners' Forum' started by rasheemo, Aug 1, 2008.
  1. rasheemo
    rasheemo TPF Noob!
    Jun 30, 2008
    162
    Wayne, NJ
    i'm not referring to gradual ND filters, i understand the uses of those. but constant ND filters. what's the point of them? can't you just underexpose the shot or something?
  2. nynfortoo
    nynfortoo TPF Noob!
    May 4, 2008
    352
    Chester, UK
    They allow you to use longer shutter speeds than you'd be able to use without an ND filter. This can be useful for adding motion to a shot in daylight.
  3. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    they also allow wider apertures. it can be hard to get a very shallow depth of field in very bright sunlight if you are already at the shortest shutter speed, it can be impossible to use f/1.4.
    the ND solves this problem.
    BTW, none of my ND filter shots is underexposed ;) this is not what they are for.
  4. rasheemo
    rasheemo TPF Noob!
    Jun 30, 2008
    162
    Wayne, NJ
    is that it? so basically if i wanted a blur shot in bright light and narrowing the aperture doesnt yield a 5 second exposure time then i should use an ND? -_-
    EDIT: oh ok, so basically for depth of field stuff. gotcha
  5. nynfortoo
    nynfortoo TPF Noob!
    May 4, 2008
    352
    Chester, UK
    Basically, it's for any situation where you want less light entering the camera, so you can keep that wide aperture or slow shutter speed without overexposing.
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    depth of field AND long shutter speeds.
    whenever it is too bright.
    there are special applications when you do industrial photography and have very bright melts or flames, then you often need a strong ND to take any image at all-.
  7. rasheemo
    rasheemo TPF Noob!
    Jun 30, 2008
    162
    Wayne, NJ
    oh i see, i guess i assumed that many pros use them and was wondering why. Ok on to graduated ND filters, i understand they rock for sunset/landscapes with bright skies, but how expensive are they relative to circular polarizers?
  8. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    it really depends on what companies you get them from.
    they are usually cheaper than good polarizers (a good polarizer is often beyond 100 USD).
    I would go for rectangular filters which you can shift to adjust the gradient to the scene you want to capture.
    Cokin does some less expensive ones, Lee is a bit more expensive. I just got my Lee-filters, but had no chance yet to use them really.
  9. Resin42
    Resin42 TPF Noob!
    Jul 16, 2008
    376
    Glasgow, Scotland
    I'm about to commit a sacrilige. I picked up my ND for about £8 on ebay.
    I know everyone says never skimp in any glass you're putting in front of your lens but I'm skint and really wanted to try some waterfall shots, plus I'm thinking of upgrading my lens shortly so didn't want to spend a fortune. It's given me an idea of what I can achieve and as far as I can tell hasn't been detrimental to my shots so I'll plod away with it until it starts to let me down.
  10. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    fair enough!
  11. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    One more note on polarizers and neutral density filters: A polarizer reduces the light entering your lens just like a neutral density filter, and can be used for that purpose in a pinch/if you're cheap with the added benefit of pulling down really bright skies. I use a polarizer for most of my daytime shooting, especially since my 35mm camera's max shutter speed is 1/2000, which tends to result in some pretty small apertures.
    Oh, and I got my polarizers for free and they haven't ruined anything yet. You'll be fine for now.
  12. rasheemo
    rasheemo TPF Noob!
    Jun 30, 2008
    162
    Wayne, NJ
    oh that sounds great.
    so one final question for you guys :D
    i'm getting a circular polarizer, and will PROBABLY get a heliopan OR a B + W CP filter, however i'm curious about tiffen's quality in comparison.
