What's this weird dial on my polarizer?
Discussion in 'Beyond the Basics' started by keller, Mar 6, 2006.
  1. keller
    keller TPF Noob!
    Sep 9, 2005
    105
    I've noticed on a polarizer, you can spin it around with this little dial (without detaching the actual polarizer from the lens). What does this do? I've noticed no effects through my viewfinder. Is it some kind of control?
  2. binglemybongle
    binglemybongle TPF Noob!
    May 23, 2005
    156
    Manchester, UK
    It allows you to adjust the amount of polarisation that the lens..... gives.
    If you look at an object through the lens that has quite a lot of highlight (say an apple in bright light - odd choice I know) and spin the filter, you should notice that the highlight dims then comes bright again with about 180' of rotation.
    I thinks thats what its for anyway. I stand to be corrected.:lol:
  3. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    That's right. You can adjust the amount of polarization right down to none.
    If you are not seeing a difference when you spin the filter, then that's not a shot that a polarizer will help...inside, for example.
    Try it outside in bright sun light...hopefully with a blue sky and or reflective water.
    Also note that a polarizer has it's strongest affect when pointed at 90 degrees to the sunlight.
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    It's not the amount, but the angle of polarization. When light bounces off a surface, it can end up polarized. Instead of the light waves "waving" along a random axis, they all align based on the surface they bounced off of. Light bouncing off the water align horizontaly. If the "slit" is aligned horizontally, all that light gets through and the camera see as your eyes do (all the light). If you rotate the "slit" 90 degrees so that it's vertical, the horizontal light can't get through. The other light does by shifting to align with the slit, but it's too far for the 90 degree light to make it. You see all the light except for the light bouncing off the surface. Without that glare, you can then see the dimmer light that comes from under the surface.
    It's more complex than that, but that's a basic explanation.
    http://polarization.com/
    http://www.bobatkins.com/photography/tutorials/polarizers.html
    http://en.wikipedia.org/wiki/Polarisation
  5. MyCameraEye
    MyCameraEye TPF Noob!
    Dec 11, 2005
    594
    12
    Washington D.C. Metro Area
    Mark K just posted what I was going to correct, "It's not the amount, but the angle of polarization".
    Scott
  6. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    I notice the effect most when there is a section of blue sky or looking at a reflection in water or off a window. It will not elimiate or reduce reflections from metalic objects like chrome on a car.
  7. keller
    keller TPF Noob!
    Sep 9, 2005
    105
    After reading that article, there's one thing I don't get - if the polarizer takes away the surface reflection, can our eyes actually see the reflection, or do we have inbuilt "polarizers" in our eyes/mind?
  8. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    We see the reflection and the polarizer reduces it or elimiates it. Say you are looking at a stream and there is a strong reflection of sky in it. With a polarizer you may be able to eliminate it and see the bottom of the stream.
