What's with the numbers?
jocose
dans la pissoir
Website
www.musingsofjocose.com
OK, so I'm still trying to figure out what to buy. I'm pretending like I have a clue, saying crap like "I'm thinking about the 18-70mm lens." But the simple fact is that I have really no idea what that means.
The camera I'm looking at comes with an 18-70mm, someone has suggested that if I get that, then I should also get a 70-300mm, and I'd be set.
Now Hobbes and Daniel are saying that I would be just as good with a 50mm. So what do these numbers mean? I know that literally, it has to do with the focal point hitting the film/sensor, but what do the numbers mean? And isn't one that has a sliding range better than a fixed one? That is, wouldn't the 18-70 DO what the 50 does?
Thanks.
Think of it in comparison to point and shoots when they talk about having a 4x or 10x zoom, etc.
A 18-70 will give you a fairly wide angle to something near our normal view of the world. A 70-300 will give you "normal" view up to a nice telephoto zoom for far away subjects. A 50mm is similar to our normal view as well, but is fixed and offers no zoom. The great thing about the 50mm is the amazing quality they offer. Generally speaking, fixed lenses tend to offer higher qualilty than zoom lenses. It really comes down to how picky you are going to be. :D
Does that help a little?
However keep in mind (in your situation at least) that nikon digital cameras have a smaller sensor area then a 35mm frame of film. What this means is that for all intensive purposes a 35mm lens is 'normal' (aka same size/proportion as your eye sees). This is due to a 1.5x factor over a 35mm film due to smaller sensor. Most folks suggest a 50mm fixed prime because their optics are supurb and the normal aspect is good for tons of compositions. However on a digital nikon it would be equivilent to a 75mm lens (aka things are 1.5 times bigger in viewfinder then naked eye). This isn't much of a change but can definitly crop out some background depending on what you want.
In all actuality I would suggest just getting the kit lens and then try it out for awhile. Lenses won't really get any more expensive so you can pick up a prime lens (35mm or 50mm) later with no real downside.
The main number(s) denotes focal length. Here is a link to a comparison of different focal lengths. You can opt for an extreme wide, wide, normal, long or very long, depending on the type of work you do.
Then there is the f/stop...
I like zoom lens personally for the flexible, as for fix lenses being better IMO that is more about cost. The high-end zoom lenses are fabulous. But, if those type of lenses are not in your budget, then yes a very good 50mm f1.4 would be better then a low-end zoom 24-85mm 3.5-4.5f
The 18-70 is not 'wide' as the 50.
the aperture number of the 18-70 is f3.5-f4.5.
whereas the widest aperture number of a single focal length 50mm that we suggested for you is f1.8. f1.8 is a scenario where the opening in the lens is wide open, therefore letting in more light, which would aid in low light shooting. If it is not a concern for you, forget about the 50, for now. Play with the 18-70 and eventually you will know which ones to add.
jocose said:
Now Hobbes and Daniel are saying that I would be just as good with a 50mm. So what do these numbers mean? I know that literally, it has to do with the focal point hitting the film/sensor, but what do the numbers mean? And isn't one that has a sliding range better than a fixed one? That is, wouldn't the 18-70 DO what the 50 does?Thanks.
Yes the kit lens zooms approximately around the same length as the 50mm, so it covers that focal length. However, the lower f-stop rating (the width) of the 50mm lens make it more useful for achieving depth-of-field effects in your shot and give you more light for those darker moments.
The biggest reason to get a prime lens in my mind is that it's going to be sharper than a zoom. It's the only way to get the best out of your camera. 18mm isn't really that wide, considering the crop factor of a Nikon DSLR and 70mm isn't that long. A standard lens is very cheap and is capable of producing awesome work and teaching you more than a thing or two.
It's my personal opinion that these mid-range zooms are a hindrance to people starting photography with an SLR. You don't need to be worrying about zoom when you're already worrying about exposure, aperture, composition, foreground, background etc. Zoom with your feet at these focal lengths. Honestly there's nothing that a 70mm lens can reach that a 50mm can't really and don't you want those extra 2 or 3 stops of light?
Rob
I personally like the fifty because it is a lot like your natural vision and it has such a wide apeture (the 1.8) so I can shoot in lower light. What I like about the focal length is that I already know what my composition in my picture is going to look like before I put the camera to my eye. With my 18-70, I have an idea of what it will look like at both ends but could have to move around some or make adjustments and the like. It's kind of petty but it's one thing I love about it. Another thing is that the 50mm is so sharp but, like Jeff said, it's because I don't have a really expensive zoom lens that delivers the same quality.
Totally agree. Just did not want to impose my opinion. With the 50mm, you are confined to just one focal length therefore helps you to focus more on the composition and exposure.
When I first ordered my first dslr, I did not get the kit zoom along with it. I got the 50 even before I got the camera! :)
50 would defenitely be an awesome way to start.
Hey everyone, thanks so much for the info...sadly, I think I'm more confused now than before ;) Now I don't know what to do as far as lenses.
As some of you might recall, I posted a thread a while back about getting my bro-in-law's camera (see over here). He has a 50mm and a 70-300mm, but both are manual focus and both are for a 35mm, not digital. How would this impact me? If I'm understanding correctly, the 50mm on the 35mm isn't 50mm on the DSLR, right? I was also told that these 2 lenses would mount onto the DSLR, but wouldn't work as well as a 500mm or 70-300mm built for the DSLR. But, since I have them anway, should I still consider them when looking into new lenses? Will someone at my level really tell the difference betwixt the 70-300mm for a 35mm on a DSLR?
There's two issues here young Jo.
Firstly is the crop factor. The sensor on a digital camera is not the same size as a 35mm film frame. It's a bit smaller. Therefore you get the centre of the image cut out at that size.
If you look at the above picture and look at the "full frame" compared to the 1.6x box you get the comparison. A 50mm lens is still a 50mm lens and takes pictures in exactly the same way as a 35mm film camera. There is no telephoto effect and the lens does not become longer. However what does happen is the equivilent of you taking a pair of scissors to a 6x4" print and cutting the middle bit out (as in the picture above). This is the effect it has on your lens. Some people explain this as a 50mm lens turning into an 85mm lens, but this isn't in the slightest bit helpful (IMO).
The second issue is that you are trying to use an older lens on a newer camera. It will physically fit, but the Tamron you have and the prime lens will probably not allow auto-focus or in fact auto anything (I would think). It is possible that the lens won't work at all, but is likely it will just be manual and you will have to set the settings on the body (annoying) manually every picture you take. I'm sure someone here will have the real story on this exact model, but I would say it's not a great lens, so don't bother.
Hope this helps
Rob.
On the advice of folks on this forum I bought an Nikon N80 35mm with a nikkor 28-80mm and 70-300mm kit.
I also bought a D50 to quickly re-learn how to compose and expose. I also bought a nikon 50mm f1.8 as people are suggesting you do here.
As a novice myself, I will tell you that after about two weeks with this setup and about 1500 shots, I like the 50mm lens the best.
The 28-80 is nice for quick impromptu shots where I don't really care to spend alot of time on moving and framing. The 300mm is a great zoom but I don't even know how to use it well yet. But the 50mm just seems to take crisper pics, forces me to move and compose and pay attention to manually photographasizing, and the big aperture (1.8) is great for DOF and time exposure (which I love!).
All three of these lenses work well, but I would take the advice here and get a 50mm f1.8 (or f1.4). You'll be glad you did, and they're only about 100 bucks;)
Hope I helped as one noob to another(?)
~DC
Your cropping graphic does help alot. Basically, if I'm understanding correctly, the 50mm, which shows all 50mm (for lack of a better description) on the 35mm film, will still see the same thing, but only the smaller bit in the middle (i.e., the size of the sensor) will actually show up on my digital "film" (i.e., the final pic that I download). So, if I were to take the exact same shot, one with my 35mm and the other with the same lens but on the digital, the pics would be exactly the same, except the digital one would be cropped on the edges. So, am I correct in that it wouldn't--in theory--effect the size of the images that appear in the picture, just what you do or do not see on the edges?
Just out of curiousity, what would I see in the viewscreen of the DSLR with the old 50mm? Will I still see what the sensor sees or what the 35mm film would see (does that make sense what I'm asking?)?
OK, so it seems I can ignore the lenses I have, which actually means that I'm technically back to the Canon 20D and the Nikon D70s, but I think that I still want the D70s, as it's cheaper, so that really is a non issue ;) Sorry, I'm just thinking out loud (well, virtually out loud anyway).
I know that with my current cam, I zoom in and out a lot. So, that makes me think that I wouldn't be happy losing that ability. Also, if 50mm lenses are cheap, perhaps I would do better to get the 18-70 and the 70-300 (as that seems to be a popular combo), and get the 50mm later (maybe for my birthday). Then again, if I go with Hobbes' opinion and ditch the warranty, I could use that same money I was planning on spending anyway and pick up a 50mm for about $94 (it says on B&H that it's "imported" does that matter?). Then I could have 3 (or 5) lenses.
The 28-80 is nice for quick impromptu shots where I don't really care to spend alot of time on moving and framing. The 300mm is a great zoom but I don't even know how to use it well yet. But the 50mm just seems to take crisper pics, and the big aperture (1.8) is great for DOF and time exposure (which I love!).
~DC
DC, you did, and I'm definitely a noob--don't let the post count fool ya ;)
Yea, see my post just above. I think now, since I have the money, I am leaning to getting all 3. Of couse, none of these lenses that I'm looking at are terribly expensive, so I could space it out a little instead of spending all at once.
First paragraph, yes - you've got it just right. The image dimensions affect the size which is where megapixels can come into it as the more image you have the bigger it can be printed at 300dpi.
Second paragraph - you've got it again. The mirror (which bounces the image to the prism and your eye) is the same sizeish as the sensor, so WYSIWYG and you see the final image (or actually about 95% of it).
Third paragraph. Yep. Possibly even consider the D50 as it's virtually the same as the 70.
Fourth paragraph - up to you. Many of us love our prime lenses and compose and take better photos as a result. For such a small sum of money it seems a good thing to buy. The Nikon lenses are imported from Japan, so as long as it's not a grey import (no problems from B&H I would think) then you'll be fine. And before you ask me about grey imports, it's normally just a tax dodge, so the only thing affected is your warranty (with genuine Nikon lenses).
Rob
