when Buying a lens for your dSLR
Discussion in 'Beyond the Basics' started by zaramuni, Jan 28, 2007.
  1. zaramuni
    zaramuni TPF Noob!
    May 16, 2006
    66
    When you buy a lens for the dSLR, the lens usually has a few numbers associated with it. One of these numbers I think is the aperture, for example, a lens that I bought said 3.5. Does this mean 3.5 is the widest my lens will go? What does it mean when they say a lens is 2.8?
  2. just x joey
    just x joey TPF Noob!
    Jan 20, 2007
    946
    Ocean City, MD
    yep, if its a 3.5 thats the widest the aperture can go.
  3. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    just different aperature capability.....the smaller the number...the larger aperature it can provide.....the faster the lense
  4. Mike_E
    Jan 26, 2007
    5,327
    265
    2.8 means that it is more expensive! lol
    With an f3.5 you can take a picture of some one walking at just after sunset with a medium lens (70-85mm 35mm film equivalent).
    At f2.8 you can take the shot between sunset and dusk.
    And at f1.4 you can take the shot at dusk (not quite dark).
    The faster and more expensive lenses will give better color rendition and will last longer as a rule but a tripod works wonders too. ;)
    mike
  5. GilTphoto
    GilTphoto TPF Noob!
    Jun 5, 2004
    28
    South Florida
    There are 3 main reasons for having or using a more expensive f/2.8 lens rather than a middle of the road f/3-f/5 lens.
    1. Optical superiority. Brighter visually through viewfinder.
    2. A larger aperature will allow faster shutter speeds. This comes in handy for shooting distant wildlife, or fast moving sports, or night scenes, when using a tripod is more difficult. The ability to get a shutter speed fast enough to handhold the camera and still get sharp pictures.
    3. A large aperature gives limited DOF which is good for isolating a subject from the background. A lens with a f/4 maximum aperature may not blur the background enough and make for a distracting or busy image.
    It boils down to considerations of budget, and what you need the lens for. If you do mostly landscapes on a tripod, fast shutter speeds are not an issue, and you usually need maximum DOF so a small aperature is needed.
    If you do wildlife or sports, you might need the faster lens.
  6. zaramuni
    zaramuni TPF Noob!
    May 16, 2006
    66
    I have a D70 so I ended up buying a lens off of ebay. Any thoughts on this lens?
    AF Nikkor 50mm f/1.8D Autofocus Lens
  7. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    this one (50mm f1.8D) is a MUST have for all DSLR users
    BEST BARGAIN
