When to bounce
Discussion in 'Photography Beginners' Forum' started by ira9700, Mar 16, 2008.
  1. ira9700
    ira9700 TPF Noob!
    Feb 24, 2008
    26
    Any sugestions just got a bower SFD35N confused as to when i should bounce
  2. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
    Always. Direct flash is never good unless it's stopped way down and it's a fill and/or it's used as a trigger for a remote flashgun. Always light the subject from a source that's away from the lens.
    I am very drunk, so don't judge these comments harshly enough. to much.
  3. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Any time you turn on the flash! Now I am not suggesting that you use the flash all the time, but I am suggesting that you bounce EVERYTIME you use the flash... as long as you can. For example, you cannot bounce outside at night. To resolve that issue, get yourself a reflector or bounce card.
    I suggest looking at www.abetterbouncecard.com and making our own.
    The SB-800 that I use has one built-in. It gets used EVERY time I turn that flash on... if it is on the camera. I strongly prefer off-camera flash, though.
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I won't say 'bounce all the time'.
    Bounce the light when you want softer lighting and when you have a surface that will provide a good bounce surface.
  5. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    I certainly use bounce most of the time. Or a tilted head and diffuser. Ideally - it's BOTH.
    But bounce will only be optimal if you have a relatively low white ceiling or are bouncing off a white wall. Just remember - the light bounced off any surface will transmit the color of that surface to your subject.
    Also, trying to use bounce when the ceiling or wall is too far away to be useful, doesn't do much for you. Just remember - the light from your flash has to travel all the way to the surface you're bouncing off of, then all the way back to the subject.
    And, oh yeah- the surface also absorbs some of that light too.
    That's why I'm never without the diffuser.
    If the color effect is minimal you can usually adjust for it in PS (assuming you know how to do it correctly). And I would certainly choose to do this and get the advantages of bounced light rather than use direct flash or no flash.
    So yeah, bounce is usually good. But be aware of the potential problems it may cause.
