When to use high pass sharpening and when to use regular sharpening methods?
Discussion in 'Photography Beginners' Forum' started by Box801, Aug 29, 2010.
  1. Box801
    Box801 TPF Noob!
    Jun 7, 2010
    51
    topic^
    I'm not really sure when to use these two methods, what makes them different?
  2. Box801
    Box801 TPF Noob!
    Jun 7, 2010
    51
    bump
  3. Box801
    Box801 TPF Noob!
    Jun 7, 2010
    51
    bump
  4. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
  5. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    High pass sharpening is actually the same technique as Unsharp Mask sharpening...it's just a different way to go about it, and with a little more flexibility.
    Sharpening is one of those things that few people fully understand (myself included). There are a few books on the subject, one that I've been meaning to read is called 'The Art of Sharpening' (or something like that).
    You could also Google yourself several days worth of reading on it.
    In a nutshell, I don't think there are any hard rules when it comes to sharpening (or photography in general, really). Sharpening is usually done to taste, so everyone is different. And different photos will respond better to different methods or strengths of sharpening.
  6. clanthar
    clanthar TPF Noob!
    Aug 2, 2010
    767
    86
    Saint Louis MO
    The differences are subtle, but:
    High pass sharpening builds more overall contrast than unsharp masking.
    High pass sharpening sharpens less overall.
    High pass sharpening is a smidge less noisy than unsharp masking.
    The problem with high pass sharpening is loss of precision. With the sharpening that takes place you are also getting a contrast increase. Two variables change together. As you get the sharpening you want are you also getting a desirable contrast change at the rate you want? You can't control the two separately and that's bad.
    Joe
  7. Taylor510ce
    Taylor510ce TPF Noob!
    Jul 20, 2010
    702
    United States
    A better technique, is to switch to L.A.B. mode. Duplicate your layer, go into the channels tab and deselect everything except the Luminosity channel ( the pic becomes black and white ) now apply unsharp mask to only this channel. Click back on all channels and go back to the normal layers tab. Now you can adjust the opacity if you need to fine tune slightly. This will sharpen the lightness info without effecting any of the color info.
    Highpass can be quick done in RGB mode though so sometimes its quicker and more convenient to use that.
  8. KmH
    Apr 9, 2009
    40,762
    5,588
    Iowa
    Not only are there multiple ways to sharpen a photo beyond using the high pass filter and L.A.B, there are up to 3 separate stages of the editing process to do so:
    1. capture
    2. local editing
    3. output
    I highly recommend the book:
    Image Sharpening with Adobe Photoshop, Camera RAW, and Lightroom, - by Bruce Fraser (RIP Bruce :thumbup:) and Jeff Schewe.
