where are these smudges from
Discussion in 'Photography Beginners' Forum' started by rlcphotos, Jun 25, 2008.
  1. rlcphotos
    rlcphotos TPF Noob!
    Nov 23, 2007
    197
    Western Pa.
    on my XT these marks have started shoeing up?? I have cleaned this lens in particular but seem to get them on all lens, I brushed the mirror lightly and blowed litely but still they are there, any help appreciated.
    The one photo I darkened so they would show up better....only seem to show on brite shots such as these
    [​IMG]
    [​IMG]
  2. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I can't see the images (probably my end, not yours) but i would think that it's dust on the sensor...not on the lens and surely not on the mirror (the mirror flips up and out of the way when the image is captured...so anything on the mirror will definitely not show up in the image).
    Cleaning the sensor is par for the course with a DSLR camera. There have been many posts about the many ways of cleaning your sensor...so use the search feature.
  5. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    It's dust and/or moisture on the sensor.
    Risky to clean. Be sure that either you or whomever you let do the cleaning knows what to do and has the correct tools. Otherwise you can ruin the camera.
  6. conradtan
    conradtan TPF Noob!
    Jan 10, 2008
    52
    San Jose, California
    Sensor dust for sure..
  7. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    Looks like sensor dust...bad enough to have to have it cleaned professionally I'd say.
  8. peterbj7
    peterbj7 TPF Noob!
    Jan 21, 2008
    118
    Oxford UK and Belize
    Agreed. You should be able to clean it yourself with Eclipse liquid and the appropriate Sensor Swab. Read the camera manual first. You'll need a fully charged battery or external power supply. It's not difficult but you do need to be very careful or you may do damage. If you have any doubts take it to Canon, or look up an authorised service agent. Make sure you're in a non-dusty environment with no air circulating. Don't be surprised if all the muck doesn't disappear on the first pass - you may need to do it twice. Do NOT re-use the sensor swab, or grit on it may score and ruin the sensor. Also get a Rocket Blower which may well shift some of the muck, now and in the future.
    I was very worried before I first cleaned my sensor, but now I've done it several times (at least once a month) I have no concerns.
    I should emphasise - ONLY use Eclipse and the right Sensor Swab on the sensor - do NOT touch it with anything else, and that includes a brush. When using the Rocket Blower hold the camera so the lens opening is facing down and be careful not to knock the mirror or sensor with the tip of the blower. Blow all around inside the camera, and any much that's just sitting in there waiting to get onto the sensor may be blown out.
  9. SBlanca
    SBlanca TPF Noob!
    Dec 28, 2007
    405
    Gibraltar
    definately sensor dust, looks quite bad, get it done with a pro, or do it yourself if you just dont care about your camera, I paid something around the region of $40 for a shop guy to clean my sensor, i just didnt dare to do it myself
  10. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Blow off the sensor with a hand blower (NOT CANNED AIR)... that should get rid of most of it... if what's left still bothers you you'll need to do a wet-clean which is a bit more risky.
  11. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    I agree. Blowing it off will most likely do the deed. Turn the mount down when you are doing it so the dust drops out easier. Wet cleaning isnt that hard if you know what you are doing.
  12. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    how often does everyone here clean their sensor? I've got the be careful changing lenses motto and its not failed me yet.
