Which camera to buy for large oil murals?
Discussion in 'Photographic Discussions' started by Silverknite, Jul 19, 2017.
  1. Silverknite
    Silverknite TPF Noob!
    Jul 19, 2017
    21
    Yes all the paintings are on canvas. The area is basically the size of a large living room so I do get very good natural lighting. What I do need suggestions on is what lights to get for the paintings that have varnish because they tend to produce reflections and are nearly impossible to photograph without any reflections showing.
    These are the ones I'm looking at so far.. thoughts and suggestions?
    Amazon.com : Nikon D3400 DSLR Camera with AF-P DX 18-55mm Lens (Black), + Flash + SLR Photo Bag + Batteries and Charger + Remote + 48GB Card Bundle : Electronics
    It might not be the longest lens but I'm sure it will be sufficient considering I have the space to place the painting far enough from the tripod and camera...if you know of a better alternative than this lens Id really appreciate it if you send me links from amazon.
    Amazon.com : Nikon AF-S DX NIKKOR 35mm f/1.8G Lens with Auto Focus for Nikon DSLR Cameras : Camera Lenses : Camera & Photo
    Thank you very much!
  2. Silverknite
    Jul 19, 2017
    21
  3. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,738
    8,137
    Iowa
    I'd go with forgoing the natural lighting and use artificial lighting with polarizers, with an opposing polirizer filter on the camera.
  4. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    Skip that bundle!!!!! They take out Nikon items and give you cheap junky knock off items (battery / charger for one, probably cables and software)!!! The only thing good in the kit is the camera and lens. Just buy the camera and its kit lens! I think $496 from AMAZON. Not a third party seller on Amazon. Sometimes they even message you saying your buying this kit, such and such is not that good would you like to upgrade this or that for $xxx more? And then they don't even sell you good stuff, but more off brand stuff.
    The 35mm F1.8 lens is good choice.
  5. Silverknite
    Jul 19, 2017
    21
    Thanks for the tip about the white balance cards, I had no idea what they were until I looked them up on amazon. Looks they come with an Instruction Guide on how to use them. Phew!
    The thing is my paintings have quite a bit of detail which means I would have to photograph each painting in sections of 6 or more to get everything in the final image for the prints. That's something I don't think I'm looking forward to getting into haha considering how much work it was to photograph each painting in two halves and putting them together in photoshop!! :)
  6. benhasajeep
    May 4, 2006
    4,021
    494
    1 or 2 of these. These are not the fastest now but for the price very good cards, and still quick. For what your doing these are more than enough. I have several for my D3300, D600. I do have slower ones as well and do just fine.
    Amazon.com: SanDisk Extreme Pro 32GB SDHC UHS-I Card (SDSDXXG-032G-GN4IN): Computers & Accessories
  7. Silverknite
    Jul 19, 2017
    21
    See.. now that's why I am here! :D Thank you for the heads up!
    Very Appreciated.
  8. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    14,406
    7,832
    Michigan
    When I was painting, some of my pieces were as big, if not bigger. I had a professional photographer do my images. He used a Mamiya 7 with a 43mm or 80mm lens (he couldn't recall) digitize my images for a dealer that took me on in Chicago. I ran into him at a funeral a couple months ago, I know he took only single frames but may have bracketed. We shot them in my studio that had major natural light coming in from all angles. He used some speed lights for fill in. I used to buy his binned photos by the shoe box. I didn't know or care anything photography then. He is a self employed professional product photographer and I was lucky enough to utilize him when he was starting out.
  9. Silverknite
    Jul 19, 2017
    21
    Found this Camera and Lens...correct me if I'm wrong but isn't the lens that comes with the camera a longer lens than the 30mm lens I linked you earlier? If it gives me the same results I just might spend $100 less
    https://www.amazon.com/Nikon-18-55mm-3-5-5-6G-70-300mm-4-5-6-3G/dp/B01N6ERCXI/ref=sr_1_8?s=photo&ie=UTF8&qid=1500591018&sr=1-8&keywords=Nikon+D3400+DSLR+Camera&refinements=p_n_feature_two_browse-bin:10705382011,p_89:Nikon
    I remember someone suggested a telephoto lens.. are there any benefits over a 30-35mm lens? If there is please be so kind to recommend one to get? :)
  10. benhasajeep
    May 4, 2006
    4,021
    494
    As for lighting your going to want softboxes. Probably 2 for your larger pieces. The should be a good size too. Large enough you may consider buying monolights or hotlights instead of flashes (monolights are just big flashes, hotlights are basically lights, called hot since they stay on all the time, just like leaving a table lamp on. Large soft boxes need more light. If your taking the pictures in your own studio and can use regular ac electric plug in lights (either hot lights or monolights). That would be less expensive. You would need lighting stands, softboxes and a way to trigger the monolights. Many have an optical sensor and by firing your on camera flash they flash also (as long as sensor picks up the camera flash). Using optical trigger you will be setting the power output on the monolights manually. Since your using digital there is only wasted time experimenting with light power and positions of the lights. You can also buy lights that have wireless triggering. With the D3400 you would also need to buy a transmitter and put on the flash hot shoe. Some of these systems are just simple triggers and you still have to set lights manually at each light. And more expensive ones you can set remotely using the transmitter mounted to the camera. And there is the old fashioned way and you can use wires. And plug in an adapter on the hot shoe and run cables to the lights. And set the lights manually.
    I myself have flashes and monolights. I use cheaper radio triggers most of the time (have to set power at each light manually). But have used optical. And I have used Nikons own wireless system which is light pulses with appropriate Nikon flashes.
  11. weepete
    weepete TPF Supporters Supporting Member
    Oct 18, 2011
    4,213
    1,308
    Glasgow, Scotland
    if you need to stitch shots together accuratley I'd really reccomend getting a rotating base, slide and an L bracket. Look in to Nodal points (basically rotating the camera around the lens aperture). Makes stitching a breeze with minimal distorsion. I do it for panoramas and I notice the difference now in post between shots around the tripod screw and when I've used the nodal point. There's various options on the market, from RRS to Nodal Ninja or you can put together your own kit. I put my own together for £160, and while that seems like a lot of extra cash it pales in comparison to a medium format digital camera. 200mpx image...no problem! Could probably put one together for your purposes for under £100, as you won't need a leveling base or indexing rotator.
    if your subject is static and using stitching you can get some fantastic detail especially with a resonably sharp lens.
  12. benhasajeep
    May 4, 2006
    4,021
    494
    Longer focal length lenses have a flattening effect. And tend to have less distortions. But you need to be farther away from the subject to get everything in the frame of the picture. If you have a long studio you can use a long lens. If you have a small room, your going to need a wider lens to get the whole artwork in the picture.
    As for the "kit" lens and the 35mm f/1.8 lens. The kit lens (18-55mm) will make you use about 2 full shutter speeds slower to take your pictures. Or maybe higher ISO settings. Or different apertures if you can't add more light. This is where some studying comes in. Need to learn the correlation between shutter speed, aperture, and iso settings. It will give you a better understanding of the differences of lens settings too (aperture). And help in purchasing lenses themselves. Basically the 35mm f/1.8 can work in lower light situations than the kit lens can. If - you can use the larger apertures in your pictures (lower numbers). So, you may not need the 35mm f/1.8 especially if you used artificial lighting. But the 35mm f/1.8 is better optically too. Will give you a better quality picture with less distortions than the kit lens. For $150 or so its a really good lens to have. The kit lens is a decent do all lens. And you can get good pictures from it. But it's a jack of all trades lens.
