Which Films to Bring + Airport X Rays
Discussion in 'Film Discussion and Q & A' started by pm63, Oct 8, 2008.
  1. pm63
    pm63 TPF Noob!
    Apr 23, 2007
    587
    London
    Hi all,
    I'm travelling to Jordan in about two weeks, and I want to test out a range of films as I'm just getting into the medium. Neg or slide, it doesn't matter, and I want some B&W films too. They have to be at ISOs I can hand-hold, so a minimum of 100 I guess. I'll be shooting mainly landscape and travel style images, if that helps, in 35mm format. So far I'm considering:
    Velvia 100
    Provia 100 (400?)
    Delta 100 (400?)
    Tmax 100 (400?)
    As you can see, I can't decide between 100 ISO for low grain, and 400 for flexibility. Any thoughts on this? Also, I like the B&W's sharp and contrasty. Does anyone have any other suggestions?
    Also, I've read that airport X-ray machines pretty much render any fast (800+) films useless, so I won't be bringing any Neopan 1600 which I was curious to test out. Can they have any effect on any of the films I'm considering?
    Any help much appreciated.
  2. Big Mike
    Dec 16, 2003
    33,853
    1,817
    Edmonton
    Airport X-ray machines probably won't render the film useless. There is some risk of fogging on higher ISO films, but that may or may not ruin it. Make sure to carry on your film, rather than keeping it in your check bags and you can even ask for a hand check rather than X-ray. It helps to take the film out of the canisters and keep them in a clear plastic bag.
  3. WinterNight
    WinterNight TPF Noob!
    Sep 14, 2008
    27
  4. pm63
    pm63 TPF Noob!
    Apr 23, 2007
    587
    London
    Thanks for the replies. I'm just not going to take any fast film. In the end I ordered (two of each, except for three Portas):
    Velvia 100
    Provia 400x
    Delta 400
    Tmax 400
    Porta 400VC
    I went for mainly 400 speeds in the end to be safe, and just for verstility with lower-light situations and more DOF. I'll be handholding, and this is a trip with school so unfortunately it'll pretty much be smash and grab, no time to really stop and take a think about composition. Also I'll be metering with my DSLR so that will take even more time too. I've heard Tmax requires really spot-on exposures so maybe I should just have gone for more Delta but I wanted to see how they compare.
  5. Cat nt Tat's Dusky
    Cat nt Tat's Dusky TPF Noob!
    Aug 20, 2008
    67
    Fort Lauderdale, Florida
    My last trip, I took all my film out of the canisters, and had it hand checked. Not a problem.
    They said anything over 800 MAY be an issue!
400 tmax film security check
can 400tmax film go through airport security
can kodak 100 tmax go through airport security
kodak t max 100 airport security
kodak tmax 100 x ray
kodak tmax 400 film in an airport?
tmax 100 and x-ray airport
tmax 100 x ray
tmax 400, airport x ray
x-ray security
