Which Fisheye?
Discussion in 'Photography Equipment & Products' started by t0bias, Jun 12, 2008.
  1. t0bias
    t0bias TPF Noob!
    Jun 12, 2008
    Hi,
    for a project I need a fisheye lens for my canon eos 40d with a fisheye effect as extreme as possible. so far i found four lenses that seem to be an option:
    - Sigma 8mm f3.5
    - Peleng 8mm f3.5
    - Sunex f5.6
    - Tokina 10-17mm Fisheye
    has anyone experiences with one or more of these lenses or does know en even more extreme fisheye? which one to purchase?
    thanks
    toby
  2. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Do you want one that fills the frame, or doesnt?
    Do you need it wide as possible?
  3. t0bias
    t0bias TPF Noob!
    Jun 12, 2008
    thanks, it doesn't matter that much, whether it fills the frame or not, but the effect should be as extreme as possible, so yes as wide as possible!
  4. Warren_G
    Warren_G TPF Noob!
    Jun 18, 2008
    65
    Saskatoon, SK
    Are you aware that Sigma makes a 4.5mm fisheye that claims to shoot 180 degrees and is designed for APS-c sensors. You need to lean forward when you shoot with it so you dont get the front of your shoes in the shot :mrgreen:
  5. S2K1
    S2K1 TPF Noob!
    Jul 5, 2007
    288
    Utah
    If you want extreme, the Sunex 5.6mm claims to give you a 185-deg. view! Never tried any of them personally however.
  6. rom4n301
    rom4n301 TPF Noob!
    Dec 28, 2007
    614
    go with the tokina cause that lens can be used on cams that arnt full frame.. also u mite wanna consider gettin the zenitar 16mm fish.. its a full frame lens but its still pretty wide and has bendage, and its only 200 dalla and has good quality
