Which head?
Discussion in 'Photography Equipment & Products' started by Overread, May 15, 2008.
  1. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Well I have recently got hold of a Manfrotto 055XPROB tripod and now need to get hold of a head to go with it.
    I was going to go for a MN-488RC2 head as I mostly shoot (or at least attempt to) wildlife, birds and the odd flower, so I wanted the flexibility of a ball head over a 3 way head.
    However since seeing some shots of the 322RC2 being used with the 055X I have been thinking of going with this head as it would allow for greater compatibility with the tripod, especially when it is the the lower positions and the center pole is at the horizontal.
    Thus I am thinking of going for the 322RC2 and then possibly getting a MN-468MGRC2 at a later date for using with slightly heavier lens set-ups than I have now.
    What are peoples thoughts on this plan - are there any heads that I should also consider or any flaws with my plan as it stands? So far I have only been able to decide that I will definitely get a right angle bracket for the tripod - even with the versatility of the 322 there will be times that I will want the head in the vertical when low down.
    The kit I intend to use with this set-up is as follows:
    All the kit listed in my sig ;)
    +canon 70-200mm IS f2.8 + 2*teleconverter (once aquired will probable be the main set-up I use - with 2* appearing every so often)
    +canon 300mm IS f2.8 + 2*teleconverter (the most in weight that I will be using in the foreseeable future)
  2. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    I had the 322rc2 head and it was great for wildlife. Had it on my 190xprob. Very versatile and locks at any position with very little creep.
    Most suited for the smaller telephotos upto about the 8lb range though it says it supports 15lbs. Not in vertical mode though. Anything off-center really is unstable. You can switch the baseplate around which is cool and it is ambidextrous. Very intuitive for panning flying birds, and running stuff. I normally had the handle on the left and panned with that while my right was on the shutter. Can splurge for the cable release if you want.
  3. uplander
    uplander TPF Noob!
    Mar 22, 2008
    536
    S.E. WI.
    I believe those were pics of my setup. The 322rc will hold a camera and a canon 100-400 lens easily. I wouldn't hesitate putting a lens up to 5 lb. lens and a camera on it.
    Just for a photo op I put my 400 f/2.8 at 12lbs + camera on it but I wouldn't try to even put that combo into use. It did hold it better than I thought it would.
    The 055XPRO / 322RC combo is pretty nice though.
    [​IMG]
  4. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    I am very curious about the 322RC2 as well, but for different reasons. I posed this question in another thread but since this one is questioning for the head, I will repeat myself.
    I already have the 488RC4 head but will be having two shoulder surgeries. The first is next week and a couple of months later the other shoulder. This will put me in the position of being a one-armed bandit for the next 6 months or so. I need a ball head that can be operated with one hand. I have a sherpa in mind to haul the gear. :lol:
    If there is one that is better than the 322RC2, please chime in. I wish to order one by the weekend.
    BTW, my longest / heaviest kit will be Nikkor 300mm f/4 and 70-200mm f/2.8 with a 1.7TC.
  5. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    hmm been looking at the cable release options - but can't work out how they work - one appears to be manual, but how you set this up with the camera is a quandry for me - the other is electric but again I can't see how to get it to work.
    http://www.amazon.co.uk/MANFROTTO-M...5?ie=UTF8&s=electronics&qid=1210888927&sr=1-5
    http://www.amazon.co.uk/MANFROTTO-E...7?ie=UTF8&s=electronics&qid=1210888927&sr=1-7
    And as you can see - amazon lists them as the same price - anyone got any experience with using either?
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Show off! :lol: We all see the other two white lenses on the mantle.
    But my question still remains....can you use the 322 as a one hand operation?
  7. soylentgreen
    Feb 27, 2007
    735
    Miami, FL
    Oh it will hold the weight, but once you tilt it off-center, things get freaky. You will need some serious wrist strength to wrangle that rig (insert jokes here). Mind you, your 100-400 is like 2 lbs though. I also had the 190 model which is a bit lighter and less stable to begin with.
    As to your question kundalini, with a cable release, it is the only one-hand operated ball head that I know of that can switch from left to right like you might need. It can support a heavy lens better side-mounted and give you better one-arm control. Slik makes a pistol grip but it looks fairly crappy.
  8. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Cheers soylentgreen.
  9. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    kundalini
    If you decide to get the 322RC2 then this is a nice little add on you might like.
    http://www.feisol.net/feisol-panning-base-pb70-p-17.html
    Well made and works smoothly. I added one to my 322 not long after I got it and never took it off. Fits so nicely together you would think that they were made for each other.
  10. soylentgreen
    Feb 27, 2007
    735
    Miami, FL
    Good luck with the surgery and a speedy recovery.
  11. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Cheers.....
    I don't mind so much getting old, but I hate feeling old. :lmao:
  12. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Well the head arrived today!
    After some playing arond with it I have set it to lefthand control so that I can use my right hand to operate the shutter. Its not ideal due to weight and the fact that I can't easily zoom (or focus) with my lens if I am tracking something.
    As a result I am no heading for a remote (birthday list now) but am still wondering if any here have tried them out - I am still wondering what sort of release they offer - is it just a single click or will they let the user half depress to autofocus?
