Which is the better deal?
Discussion in 'Photography Equipment & Products' started by bellacat, Nov 2, 2007.
  1. bellacat
    bellacat TPF Noob!
    Aug 7, 2007
    560
    North Bay California
    I am saving everything I can so I can get a Canon 40D but I am not sure what lens to get that would best serve my purpose. I will primarily shooting portraits of children and families.
    Here are the two i have been looking at this far:
    Canon EF 28-135mm f/3.5-5.6 IS lens
    or
    Canon EF 70-300mm f/4-5.6 IS USM Telephoto Zoom Lens
    Any thoughts? Is there something else I should consider instead?
  2. bellacat
    bellacat TPF Noob!
    Aug 7, 2007
    560
    so now i'm thinking its better to go with a lens with a better apiture range. I really need some advice please.
  3. Keagle
    Keagle TPF Noob!
    Sep 2, 2007
    161
    Gloucestershire, England
    Well - what's your budget? There's a lot of lenses, but the budget defines what you can get :)
  4. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    Yes, we would need to know how much you are willing to spend and what you are willing to pay for higher quality.
    The 28-135 IS, is a mid level lens. It's pretty good but not great. As mentioned, the maximum aperture isn't very large, which is limiting.
    I've heard that the 70-300 IS, is pretty good, especially compared to the cheaper 70-300 lenses...but it's still not nearly as good as either of the 4 different 70-200 L lenses. Again, the max aperture is rather small.
    Best lenses for that camera might include the 17-55 F2.8 IS and the 70-200 F2.8 L IS...both are rather expensive. The 24-70 F2.8 L, is also a fantastic lens but rather pricey.
    You might consider a fast zoom lens from another company. You can get a lens with a large aperture for much less money than Canon L...but the quality isn't as high. For example, the Tamron 17-50 F2.8 is pretty good as is the Sigma 24-70 F2.8.
  5. bellacat
    bellacat TPF Noob!
    Aug 7, 2007
    560
    I am figuring to spend on any where from $600-$800 but if i can do it for less i would. I want to buy the body separate so i get the lens i really need rather than one that is just OK
  6. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    If you have the time and room to work...prime (non zoom) lenses are great for portraits.
    1) They are usually very good optically
    2) They usually have large max apertures
    3) They usually don't cost as much as top quality zoom lenses.
    You could have a look at the Canon 50mm F1.8 (or the 50mm F1.4). The Canon 28mm F1.8 or the Sigma 30mm F1.4. Canon has a few 35mm lenses as well. The 85mm F1.8 is a great lens at a good price...good for individual shots or head shots...but may be a bit long for group shots.
    I have both the Sigma 30mm F1.4 and the Tamron 17-50 F2.8...both are quite good.
  7. bellacat
    bellacat TPF Noob!
    Aug 7, 2007
    560
    I just went out and grabbed my camera bag and i have a canon EF 75-300mm 1:4-5.6 III USM. I don't use it that often so i can tell off the bat now its not something i need. My kit lens for my 35mm is 28-88mm with .38m/1.3ft which i'm embarrassed to say I don't know what that last part means.
    I was thinking something similar in range as my 35mm kit lens would work well especially for the toddlers because they are fast and sometimes suing the zoom is faster than i can run if you know what i mean. Am I way off base here?
  8. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    The "38m/1.3ft" is probably the minimum focus distance...not really important unless you want to get close ups. The lens you mention is probably the EF 28-80mm f/3.5-5.6.
    The 'crop factor' for the 40D is 1.6...so when comparing that camera to your 35mm film camera...you should take that into account. For this reason, I suggest something like the Canon 17-55 F2.8 IS, the Tamron 17-50 F2.8, the Sigma 18-50 F2.8 or even the 70-40 F4 L, or the 16-35 F2.8 L.
  9. bellacat
    bellacat TPF Noob!
    Aug 7, 2007
    560
    thanks Mike once again you rock. What is the difference between IS and L?
  10. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    IS, is Image Stabilization. If you don't know what that is, do a search. It helps to get sharper shots at slower shutter speeds.
    L is Canon's designation for it's top of the line lenses.
    USM is Ultra Sonic Motor. This is the focus motor.
    This is better than not having USM. It should be noted that there are two types of USM...ring USM and non-ring USM. Ring USM is better...but you have to do some investigation to know which lens has which. Your 'EF 75-300mm 1:4-5.6 III USM' is not ring USM.
    A lens can have any or all of the above designations. If the lens has image stabilization...it will have IS in the name. Not all L lenses have IS...but some IS lenses are not L quality.
  11. bellacat
    bellacat TPF Noob!
    Aug 7, 2007
    560
    i am learning so much Mike...taking notes here :) I was looking on B&H and if i want auto focus i need to be sure to get Digital SLR Interchangeable Lens right? I also noticed that many say zoom super wide angle. I was looking up some of the ones you listed on B&H.
    Zoom Super Wide Angle EF-S 17-85mm f/4-5.6 IS USM Autofocus Lens for Select Digital SLR Cameras
    Zoom Super Wide Angle EF-S 18-55mm f/3.5-5.6 USM Autofocus Lens for Select Digital SLR Cameras
    sorry for all the questions but i really want to learn and you are helping me so much. also should i maybe shopping at my local camera shop for a lens instead?
  12. Keagle
    Keagle TPF Noob!
    Sep 2, 2007
    161
    They're just marketing techniques. They're zoom lenses, and 17mm is pretty wide. And yeah - you should go try out the lenses at the shop, find which one feels better to hold and use. Most of those are just replacement "kit" lenses and I second Mike's reccomendation for the Canon 17-55 F2.8 IS, the Sigma 28-70 F2.8 or even the 17-40 F4 L, or the 16-35 F2.8 L. The Sigma 28-70mm f/2.8 is supposed to be a pretty nice lens. Bear in mind the Canon 17-55mm f/2.8 IS wont work on full frame sensors if you choose to upgrade, but it's a pretty nice lens - fast and image stablised. I'm not sure of the US prices on these lenses, so they may be a bit expensive.
canon zoom lens 24-70 :2.8 macro .38m/1.3ft
compare canon lens 16-35 and 70-40
