which lens - for motor shows
Discussion in 'Photography Beginners' Forum' started by pfield, Oct 14, 2009.
  1. pfield
    pfield TPF Noob!
    Oct 14, 2009
    London
    HI, as yet I haven't purchased my camera. It will probably be a Nikon D90 or D5000. I have just over £1000 to spend initally so depending on which model I coose I can buy 1 or 2 additional lenses.
    The first 'job' I will be using it on is the NEC Motorcycle show.
    I wandered if anyone can give me advice on which lens to use at such an event. I want to take photos of cars, the event i.e. people and the models drapped over the bikes.
    I was thinking a wide angeled lens for the cars but not sure if I should swap or get a zoom lens to cover the other two. Also, will I need a fast lens and what about a flash?
    Thanks
  2. ocular
    ocular TPF Noob!
    Jul 29, 2009
    1,107
    outoftown
    If you buy the d90 keep the kit lens. ;)
  3. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,064
    2,815
    Chesterfield UK
    You don't have enough money to get 2 good fast lenses that you will need + a body
  4. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Don't do D5000, do a D90. I would recommend a 17-50 f/2.8 or a 50mm 1.8
  5. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    For motor shows, you'll probably need something wide, and if you're indoors you'll need something fast. I'd say a D90 with Tamron 17-50 f2.8. Should be both wide and fast enough for what you need and it's sharp at all apertures...even wide open.
  6. gsgary
    Oct 31, 2008
    16,064
    2,815
    Chesterfield UK
    Over here that comes to £850 so not much left for a good lens
