Which light modifer when?
Discussion in 'Beyond the Basics' started by dataz722, Sep 21, 2009.
  1. dataz722
    dataz722 TPF Noob!
    Jul 8, 2008
    55
    Newark, DE
    I am considering getting either the lumiquest softbox III or a wescott 43" umbrella. In what situations would you use one over the other? Which is more versitile?
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The lumiquest is a softbox that mount directly to your flash. It might be able to be used with the flash on the camera, but maybe not. It could certainly be used with the flash on a stand. You would need an adapter to mount the flash on a stand.
    An umbrella has to be used with the flash on a stand or something and does need an adapter.
    The Lumiquest softbox is rather small, which is good when you want something that is handy and can be packed with you. However, the softness of light is determined by the size of the light source...bigger is softer. So when comparing this to an umbrella, the umbrella will give you light that is quite a bit softer.
    Comparing an umbrella to softboxes in general (usually for studio lights)...I like softboxes because they constrain the light to one direction and a certain degree of spread. An umbrella tends to spill light all over the place, which can be a pain in some situations...but their wide spread can be great for large group shots.
