Which Pocketwizards?
Discussion in 'Photography Equipment & Products' started by keith204, Dec 14, 2007.
  1. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    From just a bit of research, there are
    Pocket Wizard Classic
    Pocket Wizard Plus II
    Pocket Wizard Multimax
    does anybody have the Ultra II or the Multimax and what's the major difference between the two?
    I got fed up with the range of my ebay triggers while shooting a basketball game last night.
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The plus II are all I can really see anyone needing, for normal wireless flash applications. They are transceivers and can be used on either the flash or the camera, and they are the cheapest, yet they work every time.
  3. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    how's the range? I can read specs, but from experience...how is it? Across a basketball court? Farther? How about obstructions? Can something be between the transceivers?
  4. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    1,600 feet line of site, really. In a office building I setup 4 strobes on the roof to fill the spire of the building at night. The PW's and flashes were behind concrete. I triggered them from ground level 11 stories below and about 800 feet from the building face. The strobes all fired every time I triggered them. No complaints on PW's from me.
  5. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    Astounding.
    Will these work with my 430EX? The 430EX has problems when hooked up to an Optical trigger or Ebay trigger. Has anyone had experience with the 430EX on a pocketwizard?
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    The PWs should work flawlessly with the 430 or any other Canon flash. I know several photographers who use them together.
  7. GHP
    GHP TPF Noob!
    Nov 28, 2007
    56
    Nanaimo, BC Canada
    Good info for me as well. I'm currently shopping around for a set and pretty much have made my mind up on PW's.
  8. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Just remember that you will probably need an extra 'hotshoe' accessory to connect the flash to the PW....since the flash doesn't have a PC port.
  9. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    Thats some good range! When I first found out about the 1600ft range I thought who is ever going to need that. Now I feel stupid.
  10. monkeykoder
    monkeykoder TPF Noob!
    Nov 19, 2007
    4,143
    Sacramento CA
    If you have 1600ft of range you're going to figure out a way to use it.
  11. jstuedle
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Yes, you can and will. I borrowed a cable that lets me trigger my Nikon through the 10 pin connector with a PW. I set the PW in my pocket and on the camera to channel 3. Then set a remote flash to channel 4. From a little over 1,350 feet (measured by rifle range finder) and through light brush fired my camera. The PW on the camera then fired the remote flash. I can't say enough about Pocket Wizards. The same technique is used to fire a remote camera and multiple off-camera strobes above the goals at basketball games. Really sweet.
  12. keith204
    May 20, 2007
    1,643
    Bolivar, MO
    I've pretty much made up my mind on the PW's.
    PROBLEM: expensive, real expensive.
    I went to the local camera shop today and they showed me the Elinchrom Skyports. They didn't know much about them, but they let me read the instruction book.
    After some brief research on the internet, I found a flickr discussion where a whole bunch of people bought them instead of PWs and love them. Basically, it's about $100 per unit, whether a receiver, or a transmitter. So, instead of paying $650 for a pocket wizard setup to fire 2 wireless flashes, it'll only cost me $300 with the Skyports to fire 2 wireless flashes.
    Also, Skyports allow "Grouping" where I can assign flash 1 to "group 1" and flash 2 to "Group 2". On the transmitter, I can set it to "Fire group 1", "Fire group 2", or even "Fire All Groups". This seems super handy.
    Pro's of Pocketwizards
    -Better Built
    -Better Range
    -Brand will probably be around longer
    -Units are transceivers
    Pro's of Skyports
    -Cheaper (huge huge huge pro, this means I can get them before the basketball tournament)
    -allows "grouping"
    -Adding units will continue the low-pricedness
    The PocketWizards have more pro's, but the price and grouping ability of the Skyports are very appealing.
    No question whether Pocketwizards are better...but I'm trying to decide which is right for me... and it seems like the Skyports would be.
    HOWEVER, the range... I mean... I really worry that I'll spend the $300 for a skyport setup and then realize the range isn't enough. Now I'm back in boat #1, where I should've bought the Pocket Wizards.
    So, how often do you guys use your pocket wizards at a distance of over 150 feet? In what scenarios would you use these at such far distances? I could totally use the extra distance at a race track to light up the dead spots... Dad gum... what am I going to do?
