Which Polarizer?
Discussion in 'Beyond the Basics' started by UUilliam, Oct 16, 2009.
  1. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Okay I have no clue about polorizers so I need someones opinion...
    Which of these is the real deal (asin not a waste of money... or will they all work the same!!)
    Hoya 58mm Circular Polarising Filter: Amazon.co.uk: Electronics & Photo
    Hoya 58mm Circular Polarizing Filter: Amazon.co.uk: Electronics & Photo
    Canon EOS 450D - 58mm High Resolution 3-piece Filter: Amazon.co.uk: Electronics & Photo < doubt it
    Hama Circular Polarizer Filter 58mm: Amazon.co.uk: Electronics & Photo
    Canon EOS Digital Rebel XSi - Hoya 58mm Circular: Amazon.co.uk: Electronics & Photo
    also is this Neutral density filter any good?
    Hoya NDX4 Neutral Density 58mm: Amazon.co.uk: Electronics & Photo
    or
    http://www.amazon.co.uk/Tiffen-58mm...1?ie=UTF8&s=electronics&qid=1255696650&sr=1-1
    any other suggestions are appreciated!
  2. Canosonic
    Canosonic TPF Noob!
    Jan 2, 2009
    660
    Germany, Bonn
    Take the hama one. I really recommend it. As far as I see it's coated.
    A Neutral density filter makes the scene darker, so you have to use lower shutter speeds (ND4 - 4 stops). This is used for motion blur for example.
    Hope I helped.
  3. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    1) Polarizers for modern SLRs should be "circular" polarizers to ensure that the metering and autofocus systems are not messed up.
    2) High quality filters do make a difference. Consider that you are adding two or more flat glass surfaces to the light path.
    3) "High quality" includes multicoating.
    4) "High quality" also includes, in some instances, multicoating specifically intended for digital sensors.
    5) A fluourescent filter and a UV filter are useless with digital cameras. IF your concern is lens protection, get a clear glass "protector" filter.
    You will need to look up the manufacturer's specs to determine which filter is high quality. At least one of your options includes "no name" filters. That makes it tough to get the manufacturer's specs.
  4. tirediron
    Jul 8, 2005
    40,936
    12,434
    Victoria, BC
    I would recommend exactly none of those. Look to either Singh-Ray, B+W, or Heliopan. Filters effectively become the first optical element in your lens, and a cheap filter is worse than nothing.
  5. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Ha ha !!!!
    the Singh-Ray costs more than my bloody lens!!!!
    Perhaps If I had the money, and a lens that it would effect greatly, I would, But on a 75-300mm USM III / 18-55mm EF-s I dont think so
    I wish I could afford them!! However, Im a student working part-time on £4.50 an hour
    in my bank I currently have £100 (did have £240 but had to pay debts + bought Call Of Duty Modern Warfare 2)
    + I use a hoya 58mm UV filter which does it's job well ( and I have witnessed a reduction in purple haze... but only slight)
  6. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    Look into a Hoya HMC lens, or SHMC if you can afford it. They are both really good quality. I have an SHMC UV filter and I could tell no degredation in quality in my tests....I still only use it when needed for me(harsher conditions for lens protection), but it's nice to know it's not killing my IQ. The HMC/SHMC Circ. Polarizer should be equally as good.
  7. tirediron
    Jul 8, 2005
    40,936
    12,434
    Victoria, BC
    Okay, that puts a slightly different spin on it. Both Hoya and Tiffen are decent, IF you get the multi-coated versions, they're more expensive, but worth it. I didn't see any of those indicating that they were multi-coated. If you can't afford one right now, you'll be better off in the long run to wait until you can.
  8. Canosonic
    Canosonic TPF Noob!
    Jan 2, 2009
    660
    Germany, Bonn
    Nobody's talking about Hama filters.:grumpy: There rare and I happen to own one. It offers great quality for a descent price.
  9. Tannachy
    Tannachy TPF Noob!
    Oct 17, 2009
    8
    New Zealand
    I just ordered what seems to be a very good and very reasonably priced Marumi DHG polariser. It is made in Japan and receives very good reviews and should be available from most European outlets from about £25-30.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Actually most multicoated filters are just fine.
    Hoya, HMC, SHMC, Kenko KMC, DMC, these filters offer an amazing performance vs price. B+W and other top of the line ones definitely don't. The law of diminishing returns comes in at a very very low point for filters, but there's a very steep rise in quality up to that point.
    I.e. a $30 filter can be absolute crap, a $50 filter can be excellent, a $200 filter can be just that little tiny bit more excellent.
  11. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    I bought the hama CPL and the tiffen Neutal density filter
  12. Canosonic
    Canosonic TPF Noob!
    Jan 2, 2009
    660
    Germany, Bonn
    So if you won't like the Hama , is it my fault?
