White Balance and film in Photoshop
Discussion in 'Graphics Programs and Photo Gallery' started by zosia, Dec 27, 2005.
  1. zosia
    zosia TPF Noob!
    Dec 27, 2005
    Sorry if these questions are a bit obvious but I'm a beginner with Photoshop so please bear with me :)
    I do like the feature in Photoshop that when you open a DNG file it immediatley brings up a palette that allows you to change the white balance.
    I photograph with film and then scan my negatives onto a CD and manipulate later on my home PC. This is probably a stupid question but is there a way that film negatives can be scanned as DNG files?
    If not, how can I adjust the white balance through photoshop?
    Note: I have the CS2 version.
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The only way to adjust white balance is by shooting with a digital camera in raw format. You can adjust the color balance to a jpg in ps using a color balance adjustment layer, a levels adjustment layer, curves, or even selective color. Unlike adjusting white balance in a dng or "raw" file, your edits will be destructive to your file. The amount of change you make to the color will determine how much you affect the file in terms of noise and artifacts. In most cases, simple color adjustments will work fine.
  3. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    Or you could always fit a filter to your camera if your shooting film and are worried about colour tints.
  4. zosia
    zosia TPF Noob!
    Dec 27, 2005
    Thanks! I thought that might be the case.
    I have tried using filters but I shoot a lot of photography under tungsten lighting and still find the cooling filter a little 'weak'.
  5. Meysha
    Feb 21, 2005
    4,152
    58
    Really? make sure you match the colour temperature of your lights to the right filter.
balancing scanned film
change white balance of film scans
change white balance scanned film photoshop
color balance in film
edit to look like film photoshop
how to corret white in scanned photo
how to white balance scanned photo
how white balance film negatives
is destructive to change white balance?
white balance film scan
