White Balance in BW
Discussion in 'Photography Beginners' Forum' started by pborgbarthet, Jul 24, 2007.
  1. pborgbarthet
    pborgbarthet TPF Noob!
    Mar 24, 2007
    70
    Malta, Europe
    Does White Balance affect Black and White shots? If I was to shoot black and white under tungsten lighting, would it make any difference what WB setting I used?
    Thanks
  2. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    Interesting question - I dont think so. I tried it and got the same cast on objects.
  3. Seefutlung
    Seefutlung TPF Noob!
    Apr 13, 2007
    1,558
    62
    SoCal
    No, white balance does not affect a B&W image. B&W is all about shades of gray and light intensity not color.
  4. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Yes it most certainly does. White balance changes the sensitivity to different colors of the spectrum. The sensor in a digital camera is far more sensitive to red than any other color. You can see this in an RGB histogram. So, if you expose a photo under tungsten lighting without setting your white balance correctly, you'll get an image with dominant reds. Once color balancing it, it becomes darker because a large portion of the light that was captured was red. This totally affects a b&w image. Open an image in photoshop, make a hue/sat adjustment layer, set the saturation to 0, and set the blend mode to color. You'll have a standard black and white image. Now select the background image and change it's hue/saturation (ctrl+u). Move the hue slider back and forth and watch the tones in the image change as the hue of the underlying photo is changed.
  5. pborgbarthet
    Mar 24, 2007
    70
    Malta, Europe
    Thanks a lot for the information. It really makes sense he way you explained it. I'll be trying it out tonight and i'll let you know the results...
    Thanks
  6. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    I use C1 LE to process my raw files. If I intend a picture to be B&W, there is a B&W preview button. I adjust the white balance to give me the best results in the B&W preview, and then export the picture in grayscale. Changing the color temperature (wb) drastically changes the look of the monochrome image.
