white balance question
Discussion in 'Photography Beginners' Forum' started by swmocity, Jul 23, 2008.
  1. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    which one of these would be correct...
    1.looks dulll
    [​IMG]
    2. just looks weird..but for some reason i like it better wow and i just noticed i put a comma rather than a period after my first initial..ill fix it late
    [​IMG]
  2. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    1 is correct, the issue is saturation, not WB.
  3. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    ohhh...let me see if i can fix it
  4. johan.sie
    johan.sie TPF Noob!
    Jul 18, 2008
    92
    hey r,
    can you share your settings for both?
    lately i have been taking lots of outdoor night pictures and I switch back and forth between Auto, and Cloudy (foggy) .. once a while i go and measure a white meter on the scene.
    I have also the dilemma you have, one seems to be a True white balance, the other to be Correct white balance (something warmer, and our eyes like more)
    i am not sure if there's any right or wrong :|
    everyone seems to have a meter for each take, i normally go for the one warmer and more natural looking, even if its kinda off from the real white you saw with your eyes
  5. tirediron
    Jul 8, 2005
    41,108
    12,494
    Victoria, BC
    Actually, I think it's a bit of WB and saturation. Looking at #1, the whites are definitely too cold. I'd say a slight warming tweak of WB and a mild saturation boost to the first image will give you a good final product.
  6. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    ok what about this one...im glad i save my raw files
    [​IMG]
  7. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    I'm personally a fan of "true white" in my photos, but I think that if the saturation was boosted either one would be fine.
  8. johan.sie
    johan.sie TPF Noob!
    Jul 18, 2008
    92
    slightly improved
    if you asked me, i really would love to see the red bricks a little red and warmer .. these seems to be so reflective from the sun rays .. do you use any filter at all?
    johan
  9. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    LOL at r. well here at the setting for the pic above
    http://www.flickr.com/photos/rpriestley/2694325627/meta/
    most of the time i leave WB on auto..i can always change it with the raw file..thats one less thing i have to worry about while actually shooting...as far as mode i use M,TV, AND AV...ive been changing alot lately
  10. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    take this picture and edit it so i can see what your talking about..if u dont mine...i have a polarizer and uv filter...i never use them though
  11. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    I think you may have overdone the saturation a hair. I think it also needs some contrast and sharpening work. Maybe a touch of perspective, too... the building looks like it's leaning forward.
    EDIT: I took a crack at it (minus the perspective correction)
    [​IMG]
    Saturation: +10ish, blue saturation: +5ish, contrast +5, Smart Sharpen: +75%, 1 pixel, gaussian
    You would likely have to change the settings on the sharpen for the original file.
    By the way, you have quite a bit of dust on your sensor... look at the space between the top of the tree and the building. Dark spots.
  12. manaheim
    Sep 2, 2005
    14,394
    3,262
    A circular polarizer would have helped here as it would have cut down the harsh glare and saturated the colors a bit more. Great to use in harsh light situations.
