Who knows about Tripods?
Discussion in 'Photography Beginners' Forum' started by Eventer, Jul 3, 2010.
  1. Eventer
    Eventer TPF Noob!
    Nov 12, 2009
    511
    10
    Christchurch, New Zealand
  2. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    It will do the job of a tripod and the lightweight construction means that it really is effortless to carry around. However you don't be using anything heavier than a 70-300mm budget line lens on it. For light lenses its ok, but don't leave it freestanding in the wind nor expect the same level of stability that a heavier set of legs would give you.
    Also note that you can only go down so far with them, since the legs cannot be splayed out.
    I used to use one (till I broke it - tip - never unscrew the panning arm on the head - they never go back in right) with my 70-300mm sigma and it was a joy to use for the fact that I could walk with camera and tripod in my hands bolted together and deploy the tripod ready for use in seconds. Effectivly it was like a 3 legged and more stable monopod for me in how I used it; but I also used it for macro work as well as regular static shot, longer exposure stuff.
    In the end I've upgraded to a heavier set of legs that offer me far more versatility, if losing the lightweight construction aspect.
  3. Eventer
    Eventer TPF Noob!
    Nov 12, 2009
    511
    10
    Sounds like it would suit me then, I have 70-300mm lens, but its a budget one - and I dont think ill be getting anything bigger for sometime. I might get and if it sucks, then hey - I only spent $23 lol. Whos knows, it might good :D
  4. Overread
    May 1, 2008
    24,062
    4,171
    UK - England
    Exactly, and if you are shooting moving subjects the weight issue isn't much of a problem since you are there to steady and hold the setup. For countering handshake though it really does make a difference having some support - especially at the 300mm end.
  5. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    this is something i discuss with my students.
    usually people want the following with a tripod, cheap, stable and light weight.
    pick any two, but you can never get all three together.
  6. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    It looks like crap. It will break apart! The legs will be held with 1 screw with plastic sleeve to aluminum. You need to spend more and buy it used.
  7. KmH
    Apr 9, 2009
    40,724
    5,587
    Iowa
    It will be better than not having a tripod, but expect to have issues with it's stability and you will find that slop in the head will make it difficult to aim the camera/lens accurately.
    Avoid raising the center column if at all possible, as that further compromises the overall stability of the tripod by raising the center-of-gravity.
  8. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    For movement sensitive shots, you probably have to use a timer or a remote if you dont want it to move a bit using that kind of tripod IMO.
  9. mommy22
    mommy22 TPF Noob!
    Dec 13, 2009
    191
    Oregon
    Looks like the POS one I have. Does the job, but not easily...
  10. Eventer
    Eventer TPF Noob!
    Nov 12, 2009
    511
    10
    Hmmm now im not sure if i should get it! haha ill have a look around at others i think... but if not then i may still get it. purely cause of the cheap price, and it might just be fine? who knows lol
  11. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    i had this tripod and i can personally tell you thats its super cheap and flimsy. i'm not really sure why I bought it. maybe cuz I got it for $10 on ebay and was cheap at the time. lol..btu anywayz the handle broke off just after a few uses and had to tape it :p I would reccommend a more solid tripod.
    the one I have right now, isn't hella flimsy or anything and has a ball head. Its about $50 on amazon, which is a fairly cheap tripod that has some quality.
    Heres the link: [ame=http://www.amazon.com/Dolica-AX620B100-62-Inch-Proline-Tripod/dp/B001D60LG8/ref=sr_1_10?ie=UTF8&s=electronics&qid=1278220878&sr=8-10]Amazon.com: Dolica AX620B100 62-Inch Proline Tripod and Ball Head: Electronics[/ame]
    good luck.
  12. ghpham
    ghpham TPF Noob!
    Dec 16, 2007
    535
    you spend ton of money on your camera but want to go cheap on the support system?
