Why my photo is darker??
Discussion in 'Photography Beginners' Forum' started by adikrist, Jul 30, 2010.
  1. adikrist
    adikrist TPF Noob!
    Jul 30, 2010
    19
    China
    It often happens that my wife photo is brighter than my photo. Somehow the face, body, and scene in my photo are darker than those in her photo. Both photos are taken with same camera setting, same distance to object, same spot, only slightly different angle.
    Why did it happen? Is it related to skin color or color of the clothing i wearing?
  2. tirediron
    Jul 8, 2005
    38,709
    11,401
    Victoria, BC
    It's hard to say, although it could well be related to differences of skin and clothing colour. Could you post an example of each, preferably with EXIF data?
  3. rusty9
    rusty9 TPF Noob!
    Apr 13, 2009
    563
    Madison, MS
    :addpics:
  4. freeze3kgt
    freeze3kgt TPF Noob!
    Apr 21, 2010
    213
    St. Louis Area
    what setting is your metering mode set at? spot, centered, or the whole picture * matrix in nikons i think its called not sure about others*
    if your at different angles it maybe that the metering is changing a bit
  5. Taylor510ce
    Taylor510ce TPF Noob!
    Jul 20, 2010
    702
    United States
    Are you both shooting in the same file format? ( Jpeg or RAW ?? ) Does one of you have a filter on their lens?
  6. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    photos would help, but just the message "slightly different angle" could be an issue. The meters in these cameras are very sensitive and it doesn't take much for a slight movement in what the lens is looking at to change the exposure.
    Perhaps your taller and are point the lens "down" and your wife may be shorter and is tilting upward. Upward brings sky into the picture, down the ground; these areas will influence the metering.
  7. adikrist
    adikrist TPF Noob!
    Jul 30, 2010
    19
    China
    Hi,
    sorry, took me quite a while to learn how to upload the image here.
    So, here it is..
    You see my wife photo on the left is brighter than mine, although position, distance to the background, etc are same. And we didn't change any camera settings, exposure level, etc.
    [​IMG]
  8. tirediron
    Jul 8, 2005
    38,709
    11,401
    Victoria, BC
    Unfortunately there is no useful EXIF data (The information such as shutter-speed, aperture, etc that the camera embeds in the image) however looking at it, it's clear to me that the image on the right is at least one stop darker than than that on the left. My only guess is that your camera was set on either 'Automatic' or a semi-automatic mode (Aperture or Shutter priority) and made changes without your knowledge.
  9. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    My money is on the difference in clothing.
    Although, since her shirt is brighter - I would expect that photo to be darker...
    Which mode was the camera on? In every mode except for Manual, even if you don't change anything, the settings could still be slightly different from shot to shot.
    For example, if you were in Aperture Priority - the aperture would never change, but the shutter speed could - resulting in a slightly different exposure.
  10. adikrist
    adikrist TPF Noob!
    Jul 30, 2010
    19
    China
    I dont have the EXIF data. Is this something i need to take note after taking picture, or can i see it using Photoshop or other software?
    The camera mode was on automatic (P). I think it made changes on shutter and aperture, due to different angle and the lens pointing down/up.
  11. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    It should be automatically saved into the picture file by the camera. Find the picture on the computer, right click on it then go to properties. The exif should be somewhere in there. On my machine it's under the 'Details' tab.
  12. adikrist
    adikrist TPF Noob!
    Jul 30, 2010
    19
    China
    Yes.. found the data..
    Her pic: shutter 1/83, aperture f/6.4, F number F/6.3
    My pic: shutter 1/83, aperture f/5.7, F number F/5.6
    So same shutter speed, did the aperture make different brightness? i thought aperture only related to the sharpness of the image in the depth of field. What does the F number mean?
    Can anyone explain this to me?
    Thank you.
