Why so expensive?
Discussion in 'The Darkroom' started by voodoocat, Sep 21, 2003.
  1. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    A 6x6 negative carrier for my enlarger is $10 on ebay. A 35mm negative carrier is $55. That is new, because there were none listed on ebay.
  2. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    I've wondered the same thing myself when looking at neg carriers in catalogs! It's two thin pieces of metal with hinges and a hole in the middle, what the heck?!
  3. carlita
    carlita TPF Noob!
    Sep 13, 2003
    690
    5
    tejas
    i'm not sure it's a matter of the 35mm carrier being expensive, but rather that you've found a 6x6 that's uncharacteristically cheap. that's most likely cause it's on ebay though. is there a reserve on that auction?
    maybe i'm just imaging this, but i thought 6x6 carriers ran at least as high as 35mm and that sounds like a pretty normal price (maybe even a smidge on the low side) for a 35mm carrier to me.
  4. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    There are about 4 6x6 negative carriers on ebay right now going for between 10-$15. I did find one 35mm that has a day left and is at $26. For now, I think I'm going to buy the 6x6 carrier and make an adapter out of cardstock to fit inside.
  5. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    i just made a neg carrier for full frame (to include sprocket holes) for 35mm.... with 25 cents worth of matt board. can do the same for any as long as you do it correctly.
  6. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    I have a Omega DII and a Beseler 23C and they both readily take homade neg carriers. I use scrap mat board and gaffer tape. I've made carriers for Widelux, 6x7cm, 6x9cm, and 2"x5" negs and they all work pretty good.
    (If you are wondering about the 2"x5" format I have modified a 4x5 darkslide so that I can take two 2x5 panos on one 4x5 sheet of film.)
    Another thing I have done is buy 35mm carriers, and use my Dremel tool to cut out larger holes. Or you can have the local machine shop do it for a few bucks.
why are negative carriers so expensive
why is gaff tape so expensive
why is gaff tape so expensive?
why the negative carriers are so expensive
