Wide angle distortion
Discussion in 'Photography Beginners' Forum' started by Emerana, May 27, 2008.
  1. Emerana
    Emerana TPF Noob!
    Jan 2, 2008
    857
    Houston, Texas
    I rented a EF-S 10-22mm f/3.5-4.5 for my upcoming trip to Chicago. I really want to do some architecture shots. I think that distorted look is cool, but how can you fix that? I am now working with lightroom and CS3 although I am VERY new to both programs.
  2. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    Couldn't you just step away from your subject?
  3. Alfred D.
    Alfred D. TPF Noob!
    May 17, 2008
    381
    What?
    Do you want that distorted look, or don't you?
  4. Emerana
    Emerana TPF Noob!
    Jan 2, 2008
    857
    Houston, Texas
    some times want it, sometimes dont. step away? hummm...isnt there a way to fix it in photoshop?
  5. asfixiate
    asfixiate TPF Noob!
    Mar 26, 2008
    817
    Near Philadelphia
    are you talking about the "fish-eye" kinda look?
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Select the entire image and use the Transform or skew command to play with it.
  7. saltface
    saltface TPF Noob!
    Apr 22, 2008
    402
    Hell's Flower Box, AZ
    Would a shift lens work? (I'm not sure if you can get one wide enough).
  8. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Yes, a tilt/shift lens is often used in architectural photography and can help you to prevent converging lines like the sides of a tall building.
    I believe the widest Canon TSE is 24mm...which isn't very wide on a crop body.
  9. Alfred D.
    Alfred D. TPF Noob!
    May 17, 2008
    381
    Yes, there is. But before someone goes to the trouble to explain it all to you, and you subsequently turn around to ask deadpan how to do the opposite – to achieve that wide angle effect – I think you better first make up your mind which you want, Emerana.
  10. Emerana
    Emerana TPF Noob!
    Jan 2, 2008
    857
    Houston, Texas
    Seriously, what are you talking about? Never freaking mind, I will figure it out on my own :thumbdown:
  11. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    In Photoshop CS2 and CS3 I think the best way is to use Filter>Distort>Lens Correction, and turn the grid on. If you do it that way on the uncropped camera image you will not affect the aspect ratio of the building. If you use the Transform tool you need to expand the top and contract the bottom, so the centerline stays the same width. The Lens Correction filter does that for you automatically.
    You don’t always need a shift lens (tilt is not usually necessary for architectural work) to get it right in camera. You can simply use a wide enough lens to get the whole building in without tilting the camera, then crop the bottom off.
    Best,
    Helen
  12. Atreus
    Atreus TPF Noob!
    Nov 13, 2007
    140
    +1 to Alfred being a snobby troll.
