Wide angle lens
Discussion in 'Photography Beginners' Forum' started by blueofspirit, Jun 17, 2010.
  1. blueofspirit
    blueofspirit TPF Noob!
    Feb 2, 2010
    43
    Hong Kong
    I'm going away on a trip into some scenic (big mountains, plains, etc.) places and want to buy a wide angle lens before I go. I own a 50D so I know there'll be the 1.6x crop limiting how wide I can go, but really want some advice on what lens I should get. Budget is probably around US$1,000 (or more if there are gems that are worth it)
    Currently thinking of the following. Any recommendations?
    1. EF 16-35mm f/2.8L II USM
    2. EF-S 10-22mm f/3.5-4.5 USM
    3. EF 17-40mm f/4L USM
    Why is the 16-35 twice as expensive as the other two? Because of the f2.8? Is it worth it if I'm going to be shooting daytime big scenery mostly?
    Thanks!
  2. j-digg
    j-digg TPF Noob!
    Jan 3, 2009
    476
    15
    Minne-snow-ta
    You could also check out the Sigma 10-20s and the Tokina 11-16, although the 11-16 is hard to get ahold of... 10mm is considered the Ultra wide on crops, the equivalent to 16mm on a full frame sensor, so you may want to go that route if you want some crazy wide shots.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    The 16-35mm and the 17-40mm, while wide angle lenses, aren't really all that wide on your camera because of the crop factor. The 10-22mm will allow you a much wider view.
    I have the 10-22mm and it's a great lens. But yes, also consider the Sigma & Tokina mentioned above.
    Partially, yes....but also because it's an 'L' lens...Canon's designation for their top of the line lenses. It has also be recently redesigned (hence the II) so it's more expensive than an older model.
    The 17-40mm is also an 'L' lens, but is actually one of the most affordable...a great bargain.
  4. dak1b
    dak1b TPF Noob!
    Jun 30, 2009
    1,554
    Northern California
    one reason why I want to go full frame
  5. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    If you want wide angle, the 16-35mm f2.8L is hard to beat. I own it and love it. The 17-40 f4L is a quality piece of L glass. In this range the Tamron 17-50 f2.8 has excellent optic quality. The build is not L glass build and the motor is a bit noisy but an excellent lens. I still keep one around because optically it is that good.
    If you want ultra-wide then the Canon 10-22 or the Toking 11-16 are both outstanding lenses. I used to own the Canon and sold it and I now have the Tokina. I needed the speed that the Tokina provided for sports. I have heard good things about the Sigma, but have never shot one so I have no first hand experience with it.
    It really comes down to how wide do you want or need to go as to what glass to get.
  6. burstintoflame81
    burstintoflame81 TPF Noob!
    Aug 7, 2009
    729
    Arizona
    I also am thinking of grabbing a wide angle soon. I had the Tokina 12-24 when I first got my camera but never used it, so I sold it. It was built like a tank though and took great shots. However, now I am probably leaning towards the Tokina 11-16 ( especially since I also have their 16-50 f/2.8 so I would have a lot of range covered ) I have heard that the 11-16 is very sharp throughout because of its short zoom range. Not sure how true it is, but I am sure its more consistent than a zoom of 10-24. Just my two cents.
  7. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    With that budget the EF-s 10-22 is really the best option (IMO).
    17-40 (or 16-35) is not wide enough on a crop body.
  8. blueofspirit
    Feb 2, 2010
    43
    Hong Kong
    Would the EFS 10-22 have crazy distortion? I'm aware of the necessary distortion but don't want photos to be like they're shot out of a fisheye lens. For reference pictures should I be looking at 16-35 samples to get a feel of what pictures will look like (given the crop)?
    Fokker - "with that budget" - what else is there if I take away the budget? Just for reference..
  9. ruaslacker2
    ruaslacker2 TPF Noob!
    Feb 2, 2008
    149
    Oklahoma
  10. Fedaykin
    Fedaykin TPF Noob!
    Mar 30, 2010
    426
    San Juan, PR
    Tokina 11-16 for sure. Slightly than the Canon 10-22 and just as good from what I've read. Just good luck finding one...
  11. fokker
    Jun 23, 2009
    2,830
    294
    New Zealand
    You won't get crazy distortion with a 10-22. To be honest there's not a heap else that goes that wide apart form the tokina 11-16 mentioned already, and the sigma 10-20. All good lenses though the canon is very well regarded and has a good zoom range. With regards to my earlier comment regarding your budget, I was more suggesting that your budget is quite healthy, and therefore you should take the canon option as opposed to a cheaper sigma. Since you already ahve the 24-70 it maeks sense to get something that covers up pretty close to the 24mm mark - the tokina (a good lens I've heard, haven't personally read any reviews or anything though) will elave you a little bit of a gap in between ultrawide and wide.
  12. Fedaykin
    Fedaykin TPF Noob!
    Mar 30, 2010
    426
    San Juan, PR
    Ah, though you meant he had a tighter budget, what I get for not reading the whole post. In that case yes the Canon would be a better option considering you have the 24-70.
