wide angle lens
Discussion in 'Photography Equipment & Products' started by spako, May 26, 2007.
  1. spako
    spako TPF Noob!
    Jan 24, 2006
    1,097
    10
    Luxemburg
    Hi,
    I'm currently owning a Canon 350D with a wide angle lens (Canon 17-40mm) and I was wondering if a 10-20mm would be a good addition to this or if it would just not be worth the money as I already have the other lens... are those 7mm really significant or should I consider buying some other gear?
    I would really appreciate any advice on this!
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    2,696
    170
    Differences in angle of view when compared to focal length travel in a geometric fashion. What that means is that angle of view changes get smaller and smaller as focal length increases and larger as it decreases. 7mm at the telephoto end of things is fairly meaningless. At the super wide angle end of things it is huge. It isn't the change in focal length that matters so much as the change in angle of view. You can look up the angle of view figures for any lens yourself and see what I mean.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    That's a huge difference. If you can use it, go ahead. I don't usually find situations where I need to go wider than 17mm on my body, so a 12-24 probably wouldn't be used much.
  4. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I think if you will use it why not.
