Wide angle lenses and some problems...
Discussion in 'Beyond the Basics' started by railman44, Oct 23, 2004.
  1. railman44
    railman44 TPF Noob!
    Aug 23, 2004
    580
    Lincoln, NE
    I'm sure there is an easy answer for this. The problem is: I'm getting some fuzzies and circular shading in the corners of my 20 and 24mm pics. The middle, of course, is sharp. What are the tricks to help solve this problem? Please keep your answer(s) simple because I ain't the brightest bulb in the room... :oops:
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I think this is fairly common for wide angle lenses. The higher quality models may not be as bad but it's something you have to live with.
    Try to keep it in mind when shooting so that you can crop off the bad parts afterward.
  3. SWFLA1
    SWFLA1 TPF Noob!
    Aug 23, 2004
    241
    Are you using a lens hood or filters? or both? It's quite possible that the lens is wide enought to be catching the edging of your attachments... Might try a couple shots without the attachments and see if it makes a difference.
    Good Luck
  4. malachite
    malachite Heavily Medicated For Your Protection
    Feb 23, 2004
    975
    6
    Not in Arizona anymore
    It's more likely the lens hood. Buy a wide angle rubber lens hood and then cut of the first 3/8" for use with 24mm and 20mm lenses. Or if you want dedicated hoods see what your particular lens manufacturer has to offer.
    Without a lens hood you're more likely to get lens flare which is easy to get with wide angle lenses and shading with your hand isn't always easy or convenient.
