Wide Angle Lenses for Canon...
Discussion in 'Photography Equipment & Products' started by LeeLeeMelis, Apr 2, 2007.
  1. LeeLeeMelis
    LeeLeeMelis TPF Noob!
    Dec 21, 2006
    135
    Maine-but currently stationed in Okinawa, Japan
    Hey there, I'm looking to purchase a wide angle lens for my Cannon EOS 30D. I will be using it for portraiture in natural light situations. I am really new to lenses, can someone give me a suggestion? Thanks!
  2. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Wide angle lenses are not usually the best choices for portraiture because wide lenses cause distortion.
    Check out the Canon EF-S 10-22mm. There are similar lenses made by Tamron, Sigma & Tokina.
  3. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Do you have an idea of how wide you want to go? I recently heard someone refer to 24mm as "very" wide angle which I would strongly disagree with, but obviously people have different ideas of what constitutes a wide angle. As Mike points out distortion tends to be an issue, but needless to say it's more of an issue the wider you go, so a moderate wide-angle might be better for your purposes. Maybe a 16-35mm zoom? Also when you say 'natural light', could this also mean low available light? If so you may want something with a larger max aperture than most zooms allow; I would possibly consider a 24mm or 28mm f/2.8 (or f/1.8 if your budget will stretch); Canon and Sigma offer both. Of course I don't know what your budget is or what lenses you already have; that might help narrow your choices down a bit.
  4. I have the 16-35mm L, and have found it to be too wide for portraits at 16mm. The crop factor makes it less apparent, but I really noticed it after I got the full-frame 5D. The distortion is the same (it's just that on a 30D the edges are cropped off).
    You can get some good results anyway:
    In the image on this page of my blog you can see a sample, but the lens was no more than a few inches from his head, definitely less than a foot:
  5. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    The last person I took a portrait of at 17mm on a 35mm sensor wants to kill me for doing so :p And I only took this image to annoy him ;)
    wide is not really a good choice for classical portraiture as it exaggerates depth and features ("huge-nose-effect").
  6. LeeLeeMelis
    Dec 21, 2006
    135
    What I want to use a wide angle lens for is for a large group of people. I have an opportunity to photograph a large number of pilots and their families surrounding an aircraft. I just assumed that this would be the lens to get. I'm also purchasing a 50mm, would that work just fine?
  7. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    That is a different story...when you say portraiture, I think about one person or maybe a small group.
    If you are shooting a large group, a wide angle lens may be required...however, there will still be distortion, especially at the sides.
    If you have space to stand back far enough, the 50mm should work just fine.
