Wide Angle Lenses
Discussion in 'Photography Equipment & Products' started by gugo747, May 31, 2005.
  1. gugo747
    gugo747 TPF Noob!
    May 31, 2005
    4
    Hi, I want to buy a wide angle lens for a hasselblad 500c/m, but i've never had one, and i dont know how big is the difference between a 40mm a 50mm (which is not as expensive as the 40mm) or the 80mm that i have right now.
    So, i was wondering if there is a website where i can see pictures taken with different lenses to compare them or if you could tell me if the pictures will really look different or not.
    thanks
  2. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    The difference between a 50mm and a 40mm on a Hassy 500CM is about the same as the difference between a 35mm and a 28mm lens on a 35mm camera. The 80mm is for the Hassy what the 50mm is for the 35mm camera. So yes, there will be a difference.
    IMHO, the 50mm Distagon is a better buy (cheaper too) than the 40mm. Yes, there is a difference in coverage but not enough to warrant buying it instead of the 50mm. Now, talking about the 30mm... That's a different story. :wink:
  3. gugo747
    gugo747 TPF Noob!
    May 31, 2005
    4
    Why do you think the 50mm is better that the 40mm besides the price??
  4. Mitica100
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Weight (40mm heavier), filter size (40mm has a 93mm size filter, an odd and expensive one, the old 50mm has a 67mm size filter, pretty common), aperture range (4-22 for the 40mm and 4-32 for the 50mm)...
    But mainly the price... :mrgreen:
