Wierd xt problem
Discussion in 'Photography Equipment & Products' started by vandecarr, Dec 7, 2007.
  1. vandecarr
    vandecarr TPF Noob!
    Nov 4, 2006
    363
    just today when i turned the camera on in Apture mode the meter wouldn't move when I changed the apture. it stayed the same from 22-1.8 I switched lenses and got the same thing.
    I tryed to take out the battries and put them back in, changing lenses, fully charging the battries, etc....it keeps happening and I can't find anything in the manual about this problem.
    If you are fimilar with it and have a fix that would be great.
    Also, when I use manual mode and it works fine.
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    had a similar same problem with my film Canon. it then even started rewinding film randomly. it came out ther ewas some dirt on the electrical camera-lens contacts
    which totally confused the camera electronics.
    might be something else in your case though ...
  3. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Um...am I missing something?
    It's not supposed to move!
    When you change your aperture, the shutter speed is changed to reflect that change, so your meter should stay the same as well...
    going from 2.0 to 2.8
    shutter speed 1/120, would change to shutter speed 1/60...and thus the same amount of light is coming in.
    Unless I"m totally missing an important factor here.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    no, maybe you miss nothing!
    i just re-read the original post carefully ... i assumed he meant the shutter speed not changeing (as in my case) ... but that is not what he wrote .... so we need some explanation what you mean here, vandecarr :D
  5. vandecarr
    vandecarr TPF Noob!
    Nov 4, 2006
    363
    okay, what was happening is the meter would stay at about a half stop under exposed.
    Anyway, I fixed it. If this happens to anyone else here is what you do....throw it against a wall at medium speed and have the f stop at 1:8......JUST KIDDING!!!!!
    Really, I cleared all the settings in the camera and that took care of it.
  6. _SnapShot_
    _SnapShot_ TPF Noob!
    Mar 2, 2007
    36
    Same as having it in program mode, setting it for one stop underexposed and wondering why it never changes.
  7. DSLR noob
    DSLR noob TPF Noob!
    Feb 7, 2007
    1,527
    7
    Atlanta, GA
    yeah it isn't supposed to move..... pressing the "AV+" and then turning the control dial moves it though if you want a slightly darker or lighter image in the future.
