Will 10mp print 20x30?
Discussion in 'Photography Beginners' Forum' started by TheMikeGuy, Jun 26, 2010.
  1. TheMikeGuy
    TheMikeGuy TPF Noob!
    Jun 26, 2010
    10
    I use a 10 megapixel Sony Alpha a230 and I am trying to find the largest size print I can make for a picture I had taken. Without distorting the image quality, do you think a print size of 20x30 will work well with a 10 megapixel SLR?
  2. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Don't see why not. I don't have the specs that some could probably give you but 10mp isn't all that bad. I wouldn't think a 3mp could do it... ya know?
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    39,611
    14,813
    USA
    It will if you use good shot discipline. You can't approach the shots willy-nilly. You need good focus, camera support, and good processing of the image. A decent lens used at a good aperture is also helpful. If you use good shot discipline, you'll be fine. If you shoot one-handed, hanging off the side of a moving boxcar using a cheap kit zoom at 18mm at f/3.5 at 1/45 second, your images might not look so hot. Make sense?
  4. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    This is pretty accurate...
    [​IMG]
  5. Phranquey
    Phranquey TPF Noob!
    Feb 16, 2008
    1,527
    11
    Dayton, OH
    Understand that you are going to be printing at roughly 130dpi, where optimum is considered 300dpi.... which means that if you stick your nose right up to the photo, you are likely to see some pixelation. If viewed from a proper distance, say farther than 4' away, it will disappear and look like a normal photo.
    As Derrel stated, the better you can make your photo to begin with, the better the larger prints will look.
  6. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    Most high quality digital print machines today will fill in color and gaps, so you should easily be able to get a decent 20x30 from a quality 10mp camera with a reasonable sized sensor..
    I have a couple on my walls from back when DSLR's had a maximum of only 6mp..
  7. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    10mp will do 20x30 just fine. I've dozens from my XTi. If you want some extra insurance, you can get something like genuine fractals which does a pretty amazing job upsizing images.
  8. DaevidClarke
    DaevidClarke TPF Noob!
    May 31, 2010
    186
    Maryland
    use my d80 (10.2mp). i print large all the time. never had a problem.
  9. KmH
    Apr 9, 2009
    40,058
    5,451
    Iowa
    A couple of points:
    • DPI (Dots-Per-Inch) is meaningless for digital photographs. It's PPI (Pixels-Per-Inch). DPI is only valid when discusing printer resolution. DPI and PPI are not the same thing. It can take as many as 8 dots to render a single pixel.
    • 300 ppi has become an arbitrary number that in the early days of digital was used to compare the quality of a print made from a digital image, to a print from a specific ASA value of print film.
    • Like Derrel mentioned, it really depends on the image, but most will be fine at substantially less than 300 ppi.
    • Most consumer print labs have printers that have a max resolution of 250 ppi.
      As an example the consumer print lab www.mpix.com stakes their very good reputation on a minimum required ppi of 100.
    • How to prepare your images. Mpix.com - Help
  10. Forest Power Ranger
    Forest Power Ranger TPF Noob!
    Jun 11, 2010
    99
    NYC
    Any thing 6/8mp and over can print real big. Look at it this way, the bigger the print, the farther away you'll stand to look at it. When you stand back you aren't going to notice the pixels. It will print it just fine.
    You don't stand 1 foot from a billboard to look at it.
10mp print size max
10mpx maximum print
biggest print size for 10mp
how big can you print a 10mp image with upsizing
largest print size for 10 megapixel
