Will guestbook work as a blog?
Discussion in 'General Shop Talk' started by rabhobbes, Feb 26, 2009.
  1. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    Hi all,
    I am on smugmug, have just set up a guestbook page...then thought, maybe I can use it as a blog (to post funny session stuff, answer questions, etc). My question is, would using it this way, instead of through a regular "blog" setup, work the same for me SEO-wise? In other words, would the search engines see the info on my site page as important as a separate blog page that's linked to my smugmug site? Just thought it would be easy to start blogging on the guestbook, since the page is already set up.
    Thanks,
    Rebecca
  2. GwagDesigns
    GwagDesigns TPF Noob!
    Jun 11, 2007
    173
    9
    Washington
    I don't believe search engines would see it the same, I also use Smugmug and blogger, you can view my site, and if you are savy enough with code, can make it look exactly like your smugmug page. having a blog is a good idea, i just dont think using the guestbook on smugmug would work quite as well.
  3. rabhobbes
    rabhobbes TPF Noob!
    Aug 29, 2007
    115
    Clearwater, FL
    Well, I turned the guestbook into a blog, and it was waaaaay easier than I thought it would be. No problem w/ the code, and with the smugmug tutorial I had it done in minutes. :thumbup:
    Thanks!
