Wireless flash 500D/580exII
Discussion in 'Photography Beginners' Forum' started by tommac, Jun 2, 2010.
  1. tommac
    tommac TPF Noob!
    Nov 30, 2009
    65
    Queenstown, NZ
    Hi everyone,
    I have an EOS 500D and a 580EXII flash. A few month ago I bought an IPHOTO wireless trigger set Speedlight Wireless Trigger for sale - TradeMe.co.nz - New Zealand .
    It has worked OK a couple of times but is generally frustratingly unreliable. So I need to take another route. Pocket wizards are just too far out of my budget at the moment to even consider. I though about a long flash chord that would work but "apparently" they only come in a 1metre length acorrding to my local shop ( www.photo.co.nz ) They also say that my built in flash can trigger my 580 which I havn't worked out yet, but I fear that the front flash will ruin the effect of off camera flash to begin with.
    Any thoughts of a solution.
    Thanks in advance from a bloody freezing cold morning in NZ.
  2. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    14,652
    2,749
    Wichita, Kansas, USA
  3. tommac
    tommac TPF Noob!
    Nov 30, 2009
    65
    Queenstown, NZ
    Thanks for this,
    I cant seem to see, is this TTL or manual?
  4. RobNZ
    RobNZ TPF Noob!
    Jan 17, 2010
    543
    New Zealand
    Heya tommac, I use a similar version of what you bought, PT-04 and mine fires 99% of the time, the 1% it doesn't is usually due to flash recycle time.
    However, I went to use them the other night and no go, grrrrrrr, so I ordered another set off eBay $23NZ shipped. Can't work without my off camera strobe!!!
    Then last night I sat down to figure out why it wasn't working, both lights working so the reciever is getting the signal to tell the flash to fire, changed batteries, checked contacts all appeared ok.
    Knowing full well that they are cheaply made chinese "crap" and the circuits are dead basic I used a multimeter to check for resistance to the hotshoe, wouldnt you know it, no circuit between the outer part of the hotshoe and wire that feeds it, took the 3 tiny screws out, bent the hotshoe back into shape (had bowed up at the edges slighlty, which caused the wire to lose contact) , tilted the wire up a little for better contact and she is now good to go, fired everytime last night.
    At least I have a spare set now, and will be handy whan I get a 2nd flash.
    So my guess on your problem, is that it could be the exact same issue, the wire to the inner part of the hotshoe is soldered on, to the outer part it is not. Or you have a dud unit.
    Pretty sure these units are all made by the one company.
    For $23 NZ you can't go wrong. I would import and sell some these on Trademe but I don't trust the quality enough for warranty purposes to retail them.
  5. tommac
    tommac TPF Noob!
    Nov 30, 2009
    65
    Queenstown, NZ
    Hey Rob,
    Thanks for your detailed explanation. I'll have a play with them tonight to find out whats wrong with them.
    Thanks again.
  6. RobNZ
    RobNZ TPF Noob!
    Jan 17, 2010
    543
    New Zealand
    No problem, let me know how you get on.
    Cheers Rob
500d wireless flash
500d remote flash
500d has wireless?
500d with 580ex ii
550d canon off camera flash wireless
canon 500d built-in remote flash
canon 500d trigger for off camera 580ex
did canon 500d have built in flash transmitter
how to set 580ex2 in 500d
iphoto wireless flash
