Wireless flash triggers
Discussion in 'Photography Equipment & Products' started by Johnboy2978, Nov 22, 2007.
  1. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    I'd like to have the mobility of not being tethered to my strobes. It was never an issue until the last wedding I shot and the 15' sync cord barely got me far enough back to get everyone in frame with my wide angle lens.
    If money were no issue I'd go for the pocket wizards of course, but it is, so I won't.
    Anyone use these or something similar?
    http://cgi.ebay.com/Digital-Wireles...ryZ30084QQrdZ1QQssPageNameZWD4VQQcmdZViewItem
    Are they reliable and dependable?
  2. Mike_E
    Jan 26, 2007
    5,327
    266
    Hi, I got mine cheaper.
    The only trouble I have had out of mine is when I first got them (one transmitter and three receivers) one of the receivers needed a contact reshaped to make contact with the battery. (be sure to remove the plastic from the battery ;))
    I do not use mine with a stand connected to the hot shoe on the receiver fearing that the part is too flimsy so instead I lash the flash to the top of the stand using ball bungees all-a strobist.
    I haven't tested just how far they reach but they will go 35 feet/behind a wall which is plenty far enough for me.
    I say give them a shot, for the price you can hardly go wrong especially if you get a spare.
    BTW the transmitter will connect via PC cable to a flash meter if you use one.
    mike
  3. FidelCastrovich
    FidelCastrovich TPF Noob!
    Aug 16, 2007
    189
    Israel
    I've got this trigger as well, and i'm pretty happy with it. Very happy, in fact. At first they would misfire quite a lot, but since i replaced the battery and played around with the channels, they seem to be working really well.
    When i get another flash or two, i'm definitely going to buy more slave triggers.
  4. Deadeye008
    Deadeye008 TPF Noob!
    Apr 24, 2007
    532
    Utah
    I bought a trigger and 2 recievers like these for under $45. One of the recievers didn't work right so they are sending me a new one. The other functioned well. I had to mod it a little to make it work with my 430EX but now it works great. I also added and extended antenna to my trigger and I can fire the flashes from about 175 ft away. Definitley worth a shot.
  5. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    What did you get and where did you get it. I'm thinking of buying some today.
  6. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Money is an issue for me, but I still went for pocket wizards. I don't want to have any worries about unreliability on a job. Also, with my Sekonic meter, I can meter wirelessly, which is huge.
    I started with two transceivers, which are about $185 each. It's enough to trigger one light and let the rest act as slaves. I'm adding another transceiver when I can and slowly building. In my opinion they are worth their price.
  7. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    Can they be used with a 580ex and a 430ex?
  8. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Yes, but you need an additional piece to make the connection. You need this adapter to give you a female sync port on the flash:
    http://www.adorama.com/FAPCHSA.html
    and then you can also purchase this: http://www.adorama.com/LTUSH.html
    to use your speedlight on a light stand with an umbrella. I do this all the time for outdoor shoots with a Promaster 7500.
    If you intend to use small flashes, consider purchasing old Nikon speed lights, because they have a sync port right on the flash, which means you don't have to buy the additional connector.
  9. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I have a cheap 'ebay' trigger. It works well enough on my older flash units or to trigger my Alienbees but it doens't work well with my Canon flash.
    I have used it at weddings but not for anything too important. I do plan to get something more reliable like Pocket Wizards.
  10. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    Great now you're being really helpful thanks. No one to blame but me for not being clear.
    Later this year I intend to buy the Bowens Gemini 500/500/500 kit but right now I'm stuck to do a small portrait job for my sister (3 kids) that she wants printed before Xmas to give as a gift.
    I have the 580ex now and that's it. I want to do a cheapo lots of gaffa tape setup just to get those shots done. So I'm thinking the 580ex bounced off some white card, and another flash on the other side doing the same thing for fill. It might just be enough!
    So I need some kind of remoter trigger system, maybe a cheapo will do? or maybe something far more substantial like the Pocket Wizards? I also need the a 2nd flash, since I'm a canon man I never look at Nikon kit so I'll look about on eBay for old Nikon speedlights, any other ideas from what I've written there?
    Thanks again.
  11. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    If you are working indoors, most flashes will have no trouble being used as optical slaves (firing when they see another flash). In this case you can use any brand flash that has a slave mode. I would also make sure that any flash you get has manual power settings so you can control the output as well. Old Nikon SB-24s can be had for $30-40 probably.
    For a cheap setup, bouncing into a large white card is a good substitute for a softbox. Another large white card for fill will work nicely. The closer you have the fill cards, the softer the light.
    As for a remote triggering system, it's up to you on how much you want to spend. If you buy that adapter I linked to, you can just use a sync cord from your camera's pc socket (if it doesn't have one, you'll need another hotshoe/pc adapter), but having wires all over the place tends to get messy, hence the want for wireless.
  12. BAB
    BAB TPF Noob!
    Dec 28, 2006
    156
    Phoenix,AZ
    I agree, you did the right thing. You pay for what you get and I have seen too many "cheap" units fail or work erratically, to be comfortable using them in a paid assignment, especially a wedding.
