Wireless Trigger
Discussion in 'Photography Equipment & Products' started by toms, Mar 24, 2010.
  1. toms
    toms TPF Noob!
    Mar 24, 2010
    Hello,
    I have a question:
    I own sony's alpha 200 and HVL-F20AM flash.
    From what i know this flash works wirelessly only with alpha 900, so I want to know-
    Somebody knows If I would buy a wireless trigger for this flash would it work (wirelessly)?
    If it should work, I will be glad if someone could recommend about one.
    If not, what can I do to make it wireless?
    Thank U,
    Tom ;)
  2. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Cybersyncs are the best value hands down.
  3. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    Using a wireless trigger is going to be a little different than using Sony's wireless system (assuming Sony works like Canon & Nikon).
    With the camera's system, the remote flash works just like it does while on the camera...automatic flash metering etc.
    But when you use a simple radio trigger device, all you can do is trigger the flash. So the flash must be fired in manual mode and you have to figure out the exposure/metering yourself.
    Also, I think that Sony's flashes have a slightly different hotshoe than most models, so if you use a trigger with a hotshoe, you might need an adapter.
  4. anel
    anel TPF Noob!
    Mar 5, 2009
    172
    i'm sorry for hijacking your thread, i just have one fast question and i don't wanna bother anyone with a whole topic because of a simple question and answer.
    - i broke my cheap ebay triggers receiver yesterday and i found a separate receiever on ebay but it's not exactly the same model, probably not even company.. but i'm thinkint it would still sync with the transmitter, or wont it? do i have to buy exactly the same set or can i do with another receiver?
  5. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Depends on what you consider the best value. :D
  6. jchin
    jchin TPF Noob!
    Mar 19, 2010
    9
    New York City
    There is an inexpensive wireless trigger that I've heard great reviews.
    It runs off the 2.4GHz band. Don't remember the brand right now.
    It was on eBay for like $50 per set.
  7. anel
    anel TPF Noob!
    Mar 5, 2009
    172
    by the way, just ordered the blazzeo wireless triggers for the second time now (it will cost me 15€, around 20$?) and they always work, like a charm.
