- Joined
- Jun 2, 2013
- Messages
- 4,493
- Reaction score
- 4,141
I don't use flash often as I prefer to use natural light, however in some circumstances it works for me. Each of these were shot using a single Canon 580EX MKI mixed with ambient light. I use ETTL as I am completely unfamiliar with manual strobing [I DO always use my camera in manual mode though, lol]. I feel like I get decent results, and am happy to share any advice and settings that I feel could help or inspire you.
The first piece of advice I can offer is to get the flash off your camera. This is basic and I'm sure someone has already posted this advice as a response to this thread. My favorite lighting advice to follow is that interesting light also requires interesting shadows. Shadows and light create depth, and in order to get both in the shot you have to make sure that the light source isn't coming from where the lens is being pointed from. I use a very long [and sometimes awkward to use] ETTL cord. It's 90ft long, but it gets my speedlite off the camera and allows me the freedom to choose the direction and angle from which the light is coming from without having to worry about a radio unit being unreliable. I got mine from here: Off-Camera Flash Gear | Canon ETTL Cord OC-E3 | Nikon ITTL Cord SC-29 | Syl Arena . I like to use a lightstand, and sometimes a GorillaPod [ JOBY flexible camera tripods for DSLR/SLR cameras and point-and-shoots ] with a hotshoe attachment. The gorillapod is very useful for location shoots where the location makes it too difficult to set up a lightstand at. You can attach it to a tree branch for example, or piping in a burnt down warehouse or abandoned house. The ETTL setting automatically meters the power of the flash needed for the exposure by reading the meter setting in the camera, and allows you to make some manual adjustments if you feel that it's too bright or not bright enough for the look you're going for. Along with getting the exposure right to your tastes, it's important to choose the direction of light to convey a particular mood or look. The best advice I can give for this is to experiment by trying different angles and locations. I always try to keep the height of the light just a little bit above my subject because I personally feel it looks more natural, but I am always trying new angles. Never limit yourself to just one look, otherwise your lighting skills wont evolve and grow.
The same can be said really for any art technique.
Using a flash will also in most cases limit your shutter speed to 1/250th of a second, or a little faster or slower depending on the sync speed that your camera is capable of, or capable of being set to. My 5D Classic, which is my main camera syncs at 1/200th of a second, while my 50D syncs at 1/250th of a second. When I first started using a speedlite I didn't realize this; I was using a fast lens set wide open at f/1.8 and didn't understand why I kept overexposing in situations where there was a lot of ambient natural light. Eventually I learned that I had to stop up the aperture in order to prevent this, because the limitation of shutter speed prevented me from using a wide open setting on my lens in order to get a properly exposed image. For most of the shots I'm posting here, I am using a Canon 85mm f/1.8 lens with the aperture set usually to at least f/3.5. This aperture setting keeps me well within the range of what I consider a good exposure, and as an added benefit the stopped up aperture setting causes the focus point to be sharper, and also widens up the depth of field just enough to keep all of the important details in focus. By all means though I encourage you to experiment with these settings. This is just what works for me. Also, get creative with how you use the light; while for some of these shots I aim the light directly at the subject, I also like to bounce the light off of walls, reflectors, or blow it through the diffusing disc the is inside my reflector kit. I'm cheap as hell, so I don't buy expensive light modifiers like softboxes and instead find cheaper alternatives like getting a friend to be my assistant and hold up the diffusing disc in front of the flash. One day when I can afford it I may look into the fancy modifiers, but that day isn't today. Anyway, sorry for the novel of a post; here are some of my shots using a speedlite, as well as the settings, light location and what I did to get the light to illuminate my subject:
For this shot I had the speedlite on a stand to camera left and had placed a mirror behind my subject to camera right in order to reflect some of that light back onto him in order to create a subtle rim lighting effect to make him pop out from the background more. I used the diffusing panel that comes attached to the speedlite in order to spread the light out a bit.
Shutter Speed: 1/160 second
Aperture: F/3.5
Focal Length: 85 mm
ISO Speed: 250
For this shot I had the flash located at camera right, however I bounced the light off a stone wall onto the model rather than aiming it directly at him. This creates softer diffused light. One thing to be careful with when bouncing light off of walls is to watch the color of the wall or object you are bouncing the light off of. If the object has color to it, that color is going to reflect back onto the subject. This can be used to your creative advantage though. I was also able to use a wider aperture setting with this shot because there wasn't a lot of ambient light, so there was little worry of over exposure.
Shutter Speed: 1/250 second
Aperture: F/2.8
Focal Length: 85 mm
ISO Speed: 160
This shot was fairly simple. There wasn't a lot of available ambient light for this shot as well, so I was able to use a wider aperture again. I had the speedlite to camera left, pointed directly at him with no modifier. This direct light mixed with low ambient light will result in higher contrast. Since there is little ambient light, details that are cast into shadow by the speedlite lose more detail causing darker shadows.
Aperture: F/2.0
Focal Length: 85 mm
ISO Speed: 250
In this shot the flash is located to camera right at a high angle to the model. The aperture was also set to 7.1, so even though there was a lot of ambient light, the flash overpowered it because the aperture setting didn't allow for too much light to enter the lens other than from the moment that the shutter opened. This is another way to create darker more dramatic shadows. Also, since there was no light source coming from the ground to illuminate him from below, the shadows are much darker.
Aperture: F/7.1
Focal Length: 85 mm
ISO Speed: 250
5.
In this shot the flash is located to camera left. Again, low ambient light contributes to darker, more dramatic shadows. I used the speedlite's on-board diffusing panel to spread out and soften the light a little bit.
Shutter Speed: 1/125 second
Aperture: F/3.2
Focal Length: 85 mm
ISO Speed: 250
6.
In this shot the flash is located to camera right. A high amount of natural ambient light allowed me to use the flash to illuminate the model while still capturing detail in his surroundings. The ambient light was also reflecting off of the surroundings and illuminating some detail in the areas that the flash cast into shadow, so the shadows aren't too dark.
Aperture: F/3.5
Focal Length: 85 mm
ISO Speed: 250
7.
This shot is a little different from the rest. The flash was the only light source along with a single dim tungsten light bulb in the ceiling behind the models. I also had a piece of lace being held about an inch away from the flash unit in order to cast some textured shadows onto the model's faces. As well, since the flash was the only light source, I used a wide aperture mixed with a high ISO setting in order to make sure that enough detail was captured in the areas that would be cast into shadows by the flash. This photo was the result of experimentation and trial and error, which is something I definitely encourage if you want to take better more interesting photos.
Aperture: F/2.2
Focal Length: 85 mm
ISO Speed: 800
8.
The flash for this shot was located to camera right, and bounced off of the silver side of my 42 inch reflector [which I purchased for $12 off of Amazon]. Bouncing the light off of the reflector filled the room with light, but the lighting still retained direction since the reflector was aimed at my subject, still causing him to have depth by casting some shadow.
Shutter Speed: 1/200 second
Aperture: F/2.8
Focal Length: 50 mm
ISO Speed: 320
I hope this was informative. Sorry again for the huge wall of text.
Aperture: F/3.5
Focal Length: 85 mm
ISO Speed: 250
Aperture: F/2.8
Focal Length: 85 mm
ISO Speed: 160
Aperture: F/2.0
Focal Length: 85 mm
ISO Speed: 250
Aperture: F/7.1
Focal Length: 85 mm
ISO Speed: 250
5.
Aperture: F/3.2
Focal Length: 85 mm
ISO Speed: 250
6.
Aperture: F/3.5
Focal Length: 85 mm
ISO Speed: 250
7.
Aperture: F/2.2
Focal Length: 85 mm
ISO Speed: 800
8.
Aperture: F/2.8
Focal Length: 50 mm
ISO Speed: 320
