Would like a lil feedback :)
Discussion in 'Photography Beginners' Forum' started by itsjustbrandy, Mar 27, 2009.
  1. itsjustbrandy
    itsjustbrandy TPF Noob!
    Aug 1, 2007
    80
    Indianapolis
    This snap is of a beauutiful umbrella tree in our front yard.
    What do you think of this picture though?
    Be brutal.. it's okay.. :lol:
    Also, this is the only one that I was even half way satisfied with. The rest just seemd real 'sketchy-like' in the background. Not even blur. I do not know how else to describe it, but more like .. grainy.
    I thought there was enough light outside... Is it the lens I'm using or maybe how I'm shooting...
    All your advice really helps, thank you so much! :hugs:
    [​IMG]
    (I didn't know if I should add this or not... I have not edited at all)
  2. tkaat
    tkaat TPF Noob!
    May 27, 2008
    307
    On a Island
    why did you remove it. It looked really good You were beating your self up to much about it. It had a good DOF decent exposure actually the exposure made it like a pic "before the rain" if you get what i mean
  3. Sherman Banks
    Sherman Banks TPF Noob!
    Feb 24, 2009
    871
    Rain City
    It's a good photo Brandy! My recommendation would be to do more to draw the viewers eye to the focal point. The photo is quite busy with the coloration and lighting, but a larger aperture, tighter crop, or even a vignetting would push the viewers eye towards the nice looking flowers you've shot.
  4. nickisonfire
    nickisonfire TPF Noob!
    Dec 24, 2008
    278
    NYC
    your picture is no longer working..
  5. itsjustbrandy
    Aug 1, 2007
    80
    Indianapolis
    There it is! I'm not sure why the pic disappeared for a brief moment. I didn't remove it.
    Anyhow- would I need a special filter to get the vignetting? OR is it possible to achieve by adjusting the setting?
    And when you shoot outdoors, is it generally better to have a larger aperature?
  6. Sodak
    Sodak TPF Noob!
    Jan 28, 2009
    104
    The vignette is a lot easier to do PP, more control. As far as ap, well it depends on what you are shooting. Here you would have gotten more dof if you would have used larger than the f/11.
    Nice picture though. I like it.
  7. Mesoam
    Mesoam TPF Noob!
    Sep 10, 2007
    1,120
    4
    CT
    just a bit over exposed, can't see much detail of the petals...
  8. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    It's a nice shot, but there is a white balance issue...image seems to have a yellow/orange color cast. Would have been nice if you got closer and tightened the shot on the flowers a bit more.
    This is the exif I got...
    ISO - 6400
    Aperture - f/5.6
    Shutter Speed - 1/4000
    Focal Length - 105mm
    Why did you use ISO 6400? This is why the pictures were grainy.
    It's the ISO setting. There probably was more than enough available light, but high ISO will produce grainy/noisy images.
    Almost all images taken with a DSLR should be post processed/edited a bit. This image could have the exposure taken down a bit, use more contrast, a little more saturation/vibrance and a little sharpening.
  9. itsjustbrandy
    Aug 1, 2007
    80
    Indianapolis
    I'm sorry.. what's PP stand for?
    Noooot reeeallyyyy sure whyyy I was shooting with ISO 6400... to be honest, I haven't really played around with the ISO. I usually only alter the aperature and shutter settings..
    So when I shoot indoors, with low lighting, I would want to use a higher ISO? And wouldn't need it so much when shooting out.. ?
    Oh and believe me.. I was trying to get in as close as I could, I just could get the lens to focus that close up.. I think its the lens? I like to get a macro! that would be nice :D
  10. Sherman Banks
    Feb 24, 2009
    871
    Rain City
    Post production- using software to manipulate/correct your photos. This is very handy to have for color correction, white balance issues, adjusting sharpness & contrast, pretty much anything you want to do to the photo.
    Your ISO is a very important setting to get to know, probably before the aperture or shutter as it will determine which aperture or shutter speed to use. A way to think of ISO is the lighter it is where you're shooting, the lower your ISO setting. You only want to shoot 800 and above when your lighting is too low to shoot with a decent shutter speed (thus preventing shake/blur). The more you push the ISO, the more noise you get in your photos. I always set my ISO first, then choose my aperture or shutter speed. Hope this helps you out!
  11. Sherman Banks
    Feb 24, 2009
    871
    Rain City
    Hope you don't mind, I made a few changes to the shot to address some of the issues people have mentioned.
    Before:
    [​IMG]
    After:
    [​IMG]
    Just changed the white balance, adjusted the exposure, pushed the contrast, added vignetting (although there are those who don't like this), all done in Adobe Camera Raw. It's still a little underexposed but I couldn't push it too much without losing the detail on the pedals. The full file would be easier to work with rather than this compressed jpeg. I'm really just learning the program but these adjustments were pretty easy to do. Let me know what you think.
  12. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Time to start learning about the basics of photography.
    Tips For Beginners - Read "The Basics Of Exposure"...very important to know this stuff.
    You might also want to pick up [ame="http://www.amazon.com/Understanding-Exposure-Photographs-Digital-Updated/dp/0817463003"]Understanding Exposure by Bryan Peterson[/ame].
    Composition Tips
    Yes, in low light situations you'll want to use a higher ISO...but remember that the higher you go the more noise you'll get in your image.
    When you're outdoors and there is good light, use a lower ISO setting. The lower the ISO setting the less noise you'll get in your image.
    Macro photography presents it's own set of challenges...lighting and focusing...but it is very rewarding.
