WTB: 35mm / 50mm f1.8 for Nikon D3000
Discussion in 'Buy and Sell' started by Tim N, Jul 13, 2010.
  1. Tim N
    Tim N TPF Noob!
    Feb 1, 2010
    33
    Virginia
    I currently have a Nikon D3000 and just wanted to look on here before going to eBay or somewhere else to buy one If you have either of the lenses listed here I'm interested in purchasing them (35mm preferred):
    Nikon 35mm f/1.8
    Nikon 50mm f/1.8
    Need to fit a D3000 body. Can be manual, don't have to be DX version unless you have one reasonably priced.
    PM or reply with what you would want for them. Thanks!
  2. jamesonharding
    jamesonharding TPF Noob!
    Jan 4, 2010
    14
    Oklahoma City, OK
    I have a Nikon 50mm 1.8 E series lens if you're interested. It's a manual focus lens.
  3. Markw
    Markw No longer a newbie, moving up!
    Jul 25, 2008
    4,051
    231
    Baltimore
    DX and AF are not the same thing. The D3000 needs AF-S lenses to autofocus. DX just means that the lenses are suited for digital cameras, not 35mm. The D3000 has a 1.5x crop factor. This means that the 50mm 1.8 is an equivalent of 75mm 1.8 on the body. Nikon does not make a 50mm DX version. The 35mm 1.8 is a DX lens. Theyre two different lenses completely, one DX and one FX. The 35mm is also an AF-S lens, so it will AF on your camera. I belive the 50mm wont as it does not have an intenal motor. To have the motor, youd have to get the 50mm 1.4. So:
    Nikon 50mm F/1.8D
    Made for FX bodies, Making it a 75mm F/1.8 equivalent on the D3000
    Will not AF on the D3000 as its not an AF-S lens
    No DX equivalent
    Nikon 35mm F/1.8G AF-S DX
    Made for DX bodies, keeping its 35mm F/1.8 equivalent on the D3000
    Will AF on the D3000 as it's an AF-S lens
    Hope this helped a little without confusing you..
    Mark
  4. shutterbugsdesign
    shutterbugsdesign TPF Noob!
    Jul 8, 2010
    48
    Philippines
    I have the 35mm. I bought that coz my camera body doesn't have built-in motor. I want something that AF and also fit my budget.
    Things to consider are your budget, AF, range...if that's any of your concern.
  5. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    Range should be first, then if you need AF, then budget. You can always save for a while longer to get the budget, but you can never get more than 35mm out of a 35mm lens only without spending more money from the aforementioned budget.
    Mark
  6. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    They do, just not in 1.8. Their 1.4 comes in a DX but it's pricey.
  7. Markw
    Jul 25, 2008
    4,051
    231
    Baltimore
    I stated that, as seen below:
    Thanks.
    Mark
50mm f1.8 series e d3000
is the nikkor 50mm 1.4 compatible with d3000
nikon 50 mm f1.8 on d3000
nikon 50mm f1.4 d3000
nikon 50mm lens e series d3000
nikon d3000 50mm f1.8
nikon d3000 f1.8
nikon f1.8 for d3000
own both 35mm 50mm
wtbuy: nikon 50mm f1.8
