X-Rite ColorMunki Spectrophotometer - a review
Discussion in 'Photography Equipment & Products' started by Edward Crim, Aug 19, 2008.
  1. Edward Crim
    Edward Crim TPF Noob!
    Apr 27, 2008
    37
    St. Louis, Missouri
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    The thing about wideband colour spectrometers is that there's a good reason many of them are prohibitively expensive.
    I haven't heard of one that can out perform a decent photodiode based colorometer (like the ones mostly used for screens) at even double the price. But since I'm looking for a cheaper spectrometer for uni based work I'm definitely happy to be proven wrong :)
    If you still have the unit could you possibly note the CIE values of a white screen with both units at once? See if they actually differ or if the software just fouled up the ICC profile creation.
  3. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    Here's an informative and fairly comprehensive review of the ColorMunki: Northlight Images.
    Best,
    Helen
  4. Edward Crim
    Apr 27, 2008
    37
    St. Louis, Missouri
    Keith has some good photos to show how the X-Rite ColorMunki works, but all he really does is reiterate what the X-Rite promotional literature says. I didn't get any useful information from his review.
  5. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    I like the way you started off the review. "Color management seems to me to be a lot like voodoo; you pay your money, do the long and complicated ritual, and maybe your enemies (bad colors, in this case) roll over and die." with a huge stress on the word "maybe". :D
  6. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    We're going to have to differ on that one. I read a lot of information in the three parts to Keith's review (intro, colour profiling and B&W) that was not in your review or the X-Rite literature. There's a lot about exactly what the processes are, how the device functions, the output resolution of the device, the format of the output data files, how the software works, how it can be used with QTR now and how QTR will provide direct support for it int he future, among other things. In short he gives an excellent introduction to the way in which the system is used and what else it can do beyond the bundled application, and what potential it has in the future.
    Your review is complementary to that information, but I felt that it left more questions than it gave answers. If I was looking for a budget spectro or an abridged spectro (I use the i1 with PM5 and a bunch of other programs) what I would be interested in seeing, after reading your review, is what you think is the cause of your problems. If your review is aimed at beginners, it might be worth explaining exactly why you had to make pdf files. I'd also be interested in a quantitative and qualitative comparison between the ColorMunki, the PrintFix Pro and the bottom-end i1 bundles. At the price of the ColorMunki it could be considered as good value solely on its performance as a print profiler.
    Best,
    Helen
  7. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    More thoughts about useful information that could be added to a review of the ColorMunki:
    Can it be used as a colour meter when hooked up to a laptop? (The i1 can, for example) This could be useful info for a photographer considering the purchase of a colour meter.
    Can/Will SpectraShop, BabelColor etc read directly from it?
    The output resolution is in 10 nm bands. Does it oversample or undersample - eg the i1 reads in 3.5 nm bands and reports in 10 nm bands (oversampling); the SP-68 measures 20 nm bands and reports in 10 nm bands (undersampling).
    Best,
    Helen
  8. Edward Crim
    Apr 27, 2008
    37
    St. Louis, Missouri
    Helen,
    Your erudite exposition of technical terms not withstanding, I suspect that most users who would look at a device such as the ColorMunki regard it as a means to the end (accurate color in the workflow) rather than the end itself.
    My only question is does it work? The answer I got was a firm "sort of".
    Caveat Emptor
  9. pcummins
    pcummins TPF Noob!
    Aug 21, 2008
    Helen: The ColorMunki takes 135 different nM band samples, so depending on how much is not considered at the start/end of the samples it looks to be on par with the i1. You can use it to capture a sample of colour using the Photo ColorPicker program by placing the ColorMunki on an object and then clicking the capture button. You can't however easily take a measurement of ambient colour or projected colour (at this time). I expect improvements in the SDK (from X-Rite) will open this possibility up for other programs to use the ColorMunki directly, but at this time it's 1st party only. Note that I've been watching the USB data directly from the ColorMunki, so I'm not sure if the above information (about nM bands and sample size) is publically written down anywhere from X-Rite.
    I have found that the profiles that the ColorMunki creates is very good. Printer profiles need a few iterative passes before the entire paper gamut is accomplished, so it's worth passing a few good pictures you like (in different colour ranges) to optimise the profile properly.
  10. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Pro Photographer had a somewhat scathing review of it in their most recent issue. They said it was fine for calibration but was a pain in the ass to figure out how to use and the instructions weren't of much help.
  11. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Here is what X-Rite say in their feature comparison table:
    " i1Photo and ColorMunki Photo feature very high resolution due to 3.5 nm physical sampling interval and 10 nm optical resolution, capturing more detail on paper and provides precise monitor and other emissive measurements such as ambient and digital projectors."
    That should work out at 100 bands of 3.5 nm, between 380 nm and 730 nm. I wonder where the other 35 are coming from.
    Best,
    Helen
  12. Edward Crim
    Apr 27, 2008
    37
    St. Louis, Missouri
    Here is an e-mail I got Wednesday:
    Edward,
    My name is Stephen Rankin and I am the product manager for ColorMunki at X-Rite. I read your recent review of ColorMunki Photo and was surprised to hear about your poor experience with the display profiling functionality. I’d be happy to speak with you when you have time and perhaps build a display profile with you over the phone if you’re interested.
    I was glad to see the printer profiling provided results that agreed with your expectations. This kind of positive experience is what most ColorMunki user are reporting with both the display profiling and the printing profiling.
    Anyway, I just thought I’d drop you this email and introduce myself. If you’d like to talk about the product, please feel free to contact me.
    Best,
    Steve.
    My Response:
    Dear Stephen,
    Thanks for the note! I would love to have you talk me through the issues I had with ColorMunki! After all, I spent almost $500 on the darn thing! I looked all over the X-rite site for someone to talk to about the issues, but could not find any specifics about whom to contact or any e-mail addresses (You might consider changing that to make your company more approachable).
    Sincerely,
    Edward Crim
    The reviews I am finding on-line aren't as favorable as Stephen seems to think, though: Check out this one (though I'm fairly certain I know what he did wrong).
    http://www.thinbits.com/2008/05/colormunki-pretty-much-doesnt.html
colormunki photo nm
colormunki qtr
colormunki spectro
colormunki spectrometer
colormunki spectrophotometer
colormunki steve rankin
photo spectrophotometer
spectrophotometer for photography
spectrophotometer reviews
x-rite sdk
