x700 problem
Discussion in 'Photography Equipment & Products' started by niccig, Jun 4, 2006.
  1. niccig
    niccig TPF Noob!
    Jun 4, 2006
    276
    Lexington, KY
    Hi everyone. I have a problem- I ebayed for a a used Minolta x700, and got it yesterday. It looked great and everything seemed to be fine, but when I got some film this morning and tried to load it I ran into some trouble. When I try to load the film, the film advance arm won't swing all the way out. The manual says if this happens, to release the shutter and the film arm will operate normally. However, when I press the shutter release, nothing happens! The seller has already agreed to take the camera back and refund my money if I can't get it to work, but I figured I'd try here before I send it back. So what do you all think - should I bother trying to fix it, or is it a dud? Thanks!
  2. PlasticSpanner
    PlasticSpanner TPF Noob!
    May 1, 2005
    4,125
    51
    Cheshire, England
    Does the shutter work OK if you take the film out and close the back?
    I used to have a problem with my X300 but cured it by setting the shutter speed to 1/60th whenever I changed the film. (which I now do on all my manual cameras)
    Another thing to check is the timer switch. Not sure if it's still the same as my X300 but it's located to the left of the lens (if you're looking at the camera from the wrong side! :lol: ) Up turns the timer on and pressed & held down is the DOF preview.
  3. niccig
    niccig TPF Noob!
    Jun 4, 2006
    276
    Lexington, KY
    No, the shutter won't work at all. The time switch is off. I tried setting it to 1/60 like you said, but that didn't work either :-( Thanks.
  4. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    Fresh battery?
  5. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    Is the mirror stuck in the up position?
    If not try a new battery like Markc suggests.
  6. niccig
    niccig TPF Noob!
    Jun 4, 2006
    276
    Lexington, KY
    Thanguys. I used brand new batteries (that was my first thought), and the mirror is ok. I spent a couple hours looking for more info on this type of problem, and apparently the capacitors that run the shutter have a habit of failing. I suspect this is the problem, though I don't think I'll take the camera apart to look, just send it back. And I was so excited about it, too.....
fixing a minolta x-700 swing arm
loadong x-700 problem
minolta x-700 advance
minolta x-700 arm
minolta x-700 arm problem
minolta x-700 shutter stuck
minolta x-700 swing arm problems
x700 advance arm stuck
x700 speeds off minolta
