YN 460 462 and manual flash
Discussion in 'Photography Equipment & Products' started by Bend The Light, Jul 2, 2010.
  1. Bend The Light
    Bend The Light No longer a newbie, moving up!
    Jun 8, 2010
    2,591
    375
    Barnsley, Oop-Nooerth, UK
    Forgive what might be a dumb question, but...
    I have a conon 400d. I am just looking now at the YN460 and YN462 on eBay and there's only a couple of quid difference. I need a flash, but I am basically broke, so I was going to buy one of these...but, I read that I wouldn't be able to use these TTL. I'm not sure what this means, and I am not sure how to use the flash, either on the hotshoe, or off camera. I believe these flashes will fire with the camera flash triggering them, but then I read about "manual" flash. What is this?
    If the flash were put on the hotshoe, would I be able to control it from camera (400d), or not? I am a novice with flash, only having the built in flash up to now.
    I'd appreciate some idea of how i would use a flash like this before I buy...I look forward to hearing your expert advice!
    Thanks
    Craig
  2. altitude604
    altitude604 TPF Noob!
    Oct 2, 2009
    720
    5
    Happy Valley-Goose Bay, NFLD, Canada
    I recently got the YN-467 off eBay myself and it's great! I'd say to save up the couple extra bucks for the 467 or 468. The only thing that cheesed me off was that the bounce card and diffuser are cheapy done so that broke the 4th time i extended them.
    It works quite well with using the on-camera flash to trigger it. Put it in to S2 and it'll work. Just have to adjust your power manually. But you can eventually eyeball how much you'll need.
    I've only just started getting into off-camera flash but it's a pretty good one to start with.
  3. Bend The Light
    Jun 8, 2010
    2,591
    375
    Just had a look on eBay - the 467 is £60 and the 468 is £69...think I might have a look at buying one of those. The 468 has digital display, and can move the zoom manually too. So, when the flash is on the camera hotshoe, the camera tells the flash what power to give if it's TTL? on a Canon 400d?
  4. altitude604
    Oct 2, 2009
    720
    5
    Yes, when the Flash is on the hotshoe of the camera it will be in E-TTL mode and the power will be controlled that way. When it's off-camera you will have to adjust that yourself.
    Oh yeah, I'm using a 450D.
  5. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
  6. Robin Usagani
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    If you want cheaper flash that works pretty well (according to other photographers), ge the NIssin Di622 or the Opteka flash
    Nissin Speedlite Di622 TTL Flash for Canon - Reviews, Features, and Prices $145 - $169 at DealTime
    [ame="http://www.amazon.com/Opteka-EF-600-EO-TTL-Digital-Camera/dp/B001GD3Z02/ref=sr_1_sc_1?ie=UTF8&qid=1278164662&sr=8-1-spell"]Amazon.com: Opteka EF-600 DG Super EO-TTL II Speed Blitz Flash for Canon EOS Digital SLR Camera: Camera & Photo[/ame]
