Zoom Lens Suggestions
Discussion in 'Nikon Lenses' started by myvinyl333, May 6, 2012.
  1. myvinyl333
    myvinyl333 No longer a newbie, moving up!
    Feb 16, 2010
    534
    32
    Eastern Iowa
    What is a suggested zoom lens for Nikon D300s/D800 along the lines of the Nikkor 28-300mm f/3.5-5.6 ED VR. I would like a smaller lens to take to baseball games and other outside events, instead of taking my 24-70/70-200.
    Thanks...
    Lens:
    Tamron SP 17-50 , SP 10-24mm XR Di
    Nikon AF Nikkor 85 ,Nikon AF Nikkor 50, AF-S 70-300, 24-70 mm 70-200mm
  2. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    You already have two of the best zooms you could mount on your camera, anything else is a step down.
    The 24-70 and 70-200 combo, although of the highest quality for zoom, is a heavy and cumbersome package. Try adding the 24-120 f/4 to your kit and see how that fits with your 70-300. I've not seen or used the 28-300 but I do have reservations about the image quality with 10x zooms.
    • Like Like x 1
  3. Nikon_Josh
    Nikon_Josh TPF Noob!
    May 30, 2011
    936
    95
    Surrey, UK
    To be honest with you and frank, I can't see how you can need another lens with the lenses you have already. You already have a 70-300 VR aswell? This should be good enough for the applications your stating and isn't too heavy. The tamron 17-50 2.8 is a lightweight mid range zoom and is perfect to cover the mid range. I don't think you need another lens or am I missing something? :er:
    • Like Like x 1
  4. myvinyl333
    Feb 16, 2010
    534
    32
    Eastern Iowa
    The Tamron 17-50 is a DX lens and I am in need of an FX for the D800. It does fine on my D300s.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    39,623
    14,820
    USA
    How about the actual NIkon 28-300? Its an FX lens, and pretty decent when shot in good light. I know it's not cheap, but...it performs pretty well. If you want to shoot baseball in good light, the 70-300 f/4.5~5.6 VR might be okay. It's reasonably sharp, and focuses "fairly" well. You could set the Function button on the D800 to "switch to high-speed crop mode", and thus run the 70-300 as a 70-300 and as a narrower-angle lens as well, depending.
