Zoombrowser How I hate thee
Discussion in 'Digital Discussion & Q&A' started by 'Daniel', Apr 23, 2006.
  1. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    Is there a way to stop Zoombrowser opening when you have finished downloading pictures form your canon?
    Also is it possible to make Digital Photo Professional to open instead?
  2. Corry
    Corry Flirtacious and Bodacious Supporting Member
    Feb 5, 2004
    21,169
    109
    North Central Illinois
    my computer is set to pop up and ASK me what I want to open it with.
  3. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    You know how you set it to do that? I looked in the various menus but couldn't really see anything.
  4. Corry
    Feb 5, 2004
    21,169
    109
    Unfortunately no, so I'm not much help to you (sorry). It's just always been that way.
  5. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    Sigh I feared as much. Anyone else.
  6. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    daniel
    what version of windows do you have......it's fairly easy to change the program associated to a particular file type.
    let me know what windows you have and i'll hopefully solve your problem
  7. 'Daniel'
    'Daniel' TPF Noob!
    Dec 30, 2004
    1,507
    14
    Manchester, UK
    Windows XP. But Its not that the RAW files are opened with that. It's that it starts up directly after the Files have d/led without choice. If I want to view them then photoshop opens.
  8. darich
    Jan 22, 2005
    1,230
    i guess then that the zoombrowser is loaded on your machine when it boots up??..or do you manually start it?
    it's possible to prevent certain programs from loading when the pc boots up. it can prevent things happening like auto file opening and speed up boot process because the pc has fewer programs to load.
  9. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    I only installed the TWAIN drivers for that reason. I hate software that comes with things for doing that kind of thing. It seems likely to me that you may need to uninstall that software and then windows should prompt with a "open folder" "open with a program" etc. when the camera is plugged in.
    Rob
  10. darich
    Jan 22, 2005
    1,230
    i prefer removing my memory card and using a card reader to avoid loading unnecessary software. Alternatively if you install the drivers for the camera you can attach the it to the pc without removing the card and read it that way.
    Either way i avoid using software i don't need to.
    To change or remove the file associations for a particular program here's what you do.
    open a folder in windows explorer.
    from the drop down menu, select "tools"
    "folder options"
    "file types" tab
    select the file type you wish to amend/delete (you can sort by clicking the column header)
    to change the program click the "change" button
    another window will open up and ask which program you wish to use.
    select "open with..." and then select the program of your choice.
    if you wish to remove the file association then select "delete" after highlighting the file type.
    Take care when doing this because any mistakes can be difficult to rectify if you can't remember which file was originally associated with a program.
    i've done this loads of times with no problems but I'm fairly computer literate. If in doubt then don't do it or consult someone who is sure.
  11. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    I don't think it's a file association - I believe it is a registry entry for the USB auto-detection for that device which has been modified to launch the program. I would think the solution would be either a registry hack to remove the association, or an uninstall of the offending program. I'm not aware of any other way of interrogating the USB behaviours, but someone else might know better.
    Rob
  12. darich
    Jan 22, 2005
    1,230
    it is possible to delete an association using the method i detailed above.
    the pc should then ask "what program?" when you try to open it.
    it may be that the program is loading automatically at startup. this can also be changed without adjusting the registry.
    The registry is a dangerous area and one slip can render the entire pc useless and in need of repair at a shop.
canon zoombrowser iphone
how to download iphone pictures in zoom browser
how+do+i+stop+or+prevent+zoombrowser launching
iphone and zoombrowser
stop zoom browser from starting
stop zoombrowser
zoombrowser and iphone
zoombrowser file association
zoombrowser for iphone
zoombrowser iphone
