Advice for: Small room Portrait Lighting
aussie27
Australia
Hi everyone, this is my first post on TPF,
I'm a beginner and have very little knowledge on lighting.
I have only a very small space in my room so I wanted a single light setup. I prefer to use a continuous light with a softbox as I want to take portraits.
I would really appreciate advice and suggestions on what type of light, what brands and also info on stands and softboxes. I have a small budget but I'm willing to spend on quality.
Thanks guys.
First of all, how small is the space, and second, how large is your budget? I would strongly recommend against continuous lights; while it seems like it would be easier, it really isn't. A nice, inexpensive strobe such as Adorama's Flashpoint 320 will do a FAR better job. You can also use a speedlight in a softbox and get very good results.
This image is a single speedlight fired into a medium softbox (okay, there is a hairlight, high, right background, but depending on the colour of your backdrop and the model's hair, that may well not be necessary):
If you go with eBay gear, such as Yongnuo flashes and triggers, the equipment (Speedlight, soft-box, trigger, and stand) can likely be had for ~$300. If you're a D-I-Y sort of person, you can save money by making your own SB, and even your own lightstand.
The minimum space that I would suggest for a bust or upper-body crop is about 8'w, 10'd and 8'h.
