OP
SIDIOUS
- Joined
- Jul 30, 2013
- Messages
- 12
- Reaction score
- 0
- Can others edit my Photos
- Photos NOT OK to edit
- Thread Starter
- #16
If I understand correctly (I haven't owned the entry-level Canons) the 100D/SL1 and the Rebels make it harder work to use manual mode than the higher level bodies, as you can't adjust both aperture and shutter speed as easily in manual mode.I like messing with manual settings, auto mode wont give me the shots I truly want, as I have learned with compact cameras.
Also, while I understand the attraction of the tiny 100D to work with, that advantage is going to disappear very quickly if you work with some of the lenses you're considering - I doubt the 8-15mm or the 15-85mm would 'balance' well enough to be comfortable to use on a body as small as the SL1. (I may be wrong on this, and to a large extent it may depend on personal preference).
Thank you for that other point I have to consider!
