JanB56
- Joined
- Sep 6, 2015
- Messages
- 29
- Reaction score
- 6
- Location
- Atlanta, Ga
- Can others edit my Photos
- Photos NOT OK to edit
That's what I have been finding out, good explanation DerrelShooting at f/1.8 with say a 50mm f/1.8 lens, or a 35mm f/1.8 or 85mm f/1.8 lens is called shooting wide-open. Shooting wide-open means the depth of field band will be as narrow as is possible with that lens. If the lens is closed down one f/stop, there will be a little bit more depth of field. if the lens is closed down two full f/stop values from wide-open, there will be a bit more in-focus, a little bit deeper of a depth of field band. At three full f/stops below maximum aperture, there will be even more of a depth of field band, and enough to start giving you a bit of leeway on focusing, so that focusing is not utterly critical.
If you want to shoot at a SPECIFIC f/stop setting, like say f/1.8 or f/2.5, or f/3.2, I would suggest using A-mode on Nikons, Av mode on Canons; this is Aperture-priority auto on a Nikon, and Aperture value mode on a Canon--they are identical in function. This allows you to choose your priority value, which is the Aperture, and the camera adjusts the shutter faster or slower for the lighting levels.
I will give you a little tip: on people photos, at close shooting distances, like say 6 to 15 feet, shooting at f/1.8 often causes missed focus, or too shallow of a depth of field, and results in inferior photos. It's almost always better to close the lens down a bit, to say f/2.8 or so, or f/3.2, and shoot there; those aperture settings are still quite large, and let in a lot of light, but they also give a little bit better optical quality, and they give you a very slight bit of leeway on focusing errors, so that you can get a good picture even if you miss the focus by an inch or two. AT CLOSE RANGES, the f/stop used becomes very important as far as making an images either usable, or not usable. At distances of less than 10 feet, a very small focusing error can be disastrous, especially at f/1.8.
In all honesty, I think that for most people photography, using an aperture value of from f/4 to f/5.6, from 7 to 15 feet away is the best overall aperture setting range for getting a really good, usable image on the highest percentage of photos. Again--the CLOSE DISTANCE is what gives that nice, blurred background...the closeness is a little bit more of a factor in producing the out of focus background than the aperture used...being closer to the subject is what causes the depth of field to drop off rapidly in the area BEHIND the subject plane; the benefit to an f/stop like f/4 to f/5.6 is that you gain some sharpness right at the subject's plane, for a foot to two feet, but then the stuff well behind that distance drops off into out of focus-ness.
Start testing your knowledge with a stationary subject and a measuring tape.
measure your distance to the subject and measure the respective DOF
More Clouds and Composition Effort | Photography Forum
by using a DOF calculator
A Flexible Depth of Field Calculator
Also you focus point is very important.
You have not mentioned your specific equipment
so I'm going to assume, say a nikon d7000
you want to set the Focus points on AFS-Single
Do not let the camera choose for you, so don't use AFC-d39
and practice focusing on the eye, or the specific subject you want as your DOF will take other things OOF. If someone is standing partially sideways you could easily get one eye in focus and the other eye out of focus unless you use the correct aperture setting, and correct DOF for both eyes.
So check each photo in the LCD screen for selected focus point and make sure it's what you wanted.
And practice, practice, practice. The measuring tape really hammers home the DOF calculations.
Hey, don't stress it! Nobody is born with the ability to "just know" how to calculate the DOF, that's why somebody has put that thing online.I have purchased 4 diff lens, 50mm 1:8G - 18-55 5.6G - 35mm 1.8G & 55-200mm 5.6G , which would be better for shooting to get the best DoF & which do you consider the worst ?
Any of the lenses you have will be fine at f/5.6. The closer you stand to people, the more-critical absolutely dead-on accurate focusing becomes. I personally think that seven feet is the absolute closest you ought to ever be when doing people photography, unless you want distorted hands, arms, legs, noses, etc.. For pleasing, portrait-type photos of people, I think it's easier to be a little bit farther away from them, say 10-15 feet, and to use a zoom lens to get the right framing. If you shoot portraiture at f/5.6, you almost always can hit focus, even on two people, and as long as you are in the 12 to 20 foot distance range, focusing is not super-critical, the way it is at the closest distances.
If you want to do say a very tight head shot, you could use the 35mm lens from three feet away, OR move back, and use say the 55-200mm lens from 15 feet; moving back, and using the longer lens will result in a different picture, with the SAME head size in the frame. My vote is almost always for a longer lens, from a bit farther back, than it is shootjng from too close a distance.
As for "best DOF", what exactly are you going for? Usually people want the subject(s) to be IN FOCUS, and the background and foreground OUT OF FOCUS, so I'll use that premise as the starting point for formulating my answer.
To get somewhat of a shallow DOF, while keeping your subject in focus, you're going to have to plug in the numbers yourself because we won't know how far away from the camera your subjects are. That being said, I would suggest the longer lens to minimize distortion of being way too close to your subjects. The 50 mm might work, but then so would the 55-200mm if the background was far behind the subjects.
