gsgary
- Joined
- Oct 31, 2008
- Messages
- 16,143
- Reaction score
- 3,002
- Location
- Chesterfield UK
- Website
- www.gsgary.smugmug.com
- Can others edit my Photos
- Photos OK to edit
Vosges mountains are not far from you
With higher elevation air temperatures are lower too - about 1° for every 1000 feet.Because with elevation air becomes thinner very rapidly. However, a few hundred meters probably wouldn't suffice. This is why telescopes are frequently built on tall peaks.
In the area you're looking at, the wooded areas between D4 and D66 look promising. Seeing conditions are a function of humidity, aerosol particulates, sky glow, and reflected light from terrestial sources. As noted earlier by myself and astroNikon, the best transparency is usually right after a front passes through, with the rain cleaning up the atmosphere. If you can find a place which is surrounded by forest, then that helps with local light back-scatter. Usually, if the lower 20 degrees of azimith are hidden by trees, or other objects, that's not a major issue. To know what you 'll be looking at, use the freeware program Stellarium (Stellarium), which you can instruct to show the sky from any point on Earth.
